[U200 Feedback] Unlock vs. Unlatch – Important Issue for Doors Without Outside Handle (Turkey use case)
Hello Aqara team and community,
I am writing from Turkey, where I recently invested a considerable amount of money in the Aqara U200 smart lock and an Aqara Hub M2. I am generally happy with the product, but I would like to share an important feedback point regarding the lock configuration and local door types here in Turkey.
During setup, the U200 asks about lock type (EU lock, UK lock, US lock, etc.). However, in my opinion there is a critical missing question: “Does the door have an outside handle that can retract the latch?”
Here in Turkey, 99.99% of apartment entrance doors do not have an outside handle. Once U200 is installed, there is no mechanical way to retract the latch from outside — only the motorized mechanism can do it. This means:
If Pull Spring (unlatch) is disabled, unlocking only the deadbolt leaves the latch in place, making it impossible to open the door from outside.
If Pull Spring is enabled, then both the deadbolt and latch retract, which allows opening the door.
The problem: In the current app UI (main screen), there are two buttons: “Unlock” and “Unlock + Unlatch.” But in practice, even when I press only “Unlock,” the latch is also retracted. This behavior creates both confusion and a potential security issue because there is no clear distinction.
I kindly suggest adding this “outside handle: yes/no” option in the setup wizard to prevent misconfiguration and to ensure safety. It would avoid situations where users (like me) might accidentally configure it wrong and end up locked out or with reduced security.
A bit about me: I am 36 years old and discovered Aqara by chance. I researched the U200 carefully and realized it is one of the rare products that combines latch retraction, NFC tags, fingerprint, temporary password, and keypad access in one device. With the help of AI and personal research, I decided to purchase it even though the cost is quite high in my country. At home, I also use around 40 other smart devices (LED strips, smart switches, climate control, sensors, etc.), and Aqara has become a central part of this ecosystem.
:point_right: My request: Please confirm if future firmware (such as v84 and onwards) will address this behavior and provide a clear separation between “Unlock only” and “Unlock + Unlatch.” This is essential for countries like Turkey where almost all apartment doors lack outside handles.
Thank you for listening to this feedback. I sincerely hope Aqara continues improving this product so I can use it with full confidence and proudly recommend it to my family and friends.
@AqaraBot
Kind regards, Özgen from Turkey
@ozgenserem Thank you so much for your detailed feedback and for sharing your experience with the Aqara U200 in Turkey! Your insight into local door designs—specifically the prevalence of doors without outside handles—is incredibly valuable, and you’ve articulated the challenge with clarity. Your suggestion to add an “outside handle: yes/no” prompt during setup makes a lot of sense and could indeed help prevent misconfiguration, especially in regions where door styles differ from the default assumptions.
Regarding your core question: Based on the latest available reference information, the U200 does support the “Pull Spring Feature,” which is specifically designed to retract the latch for doors without an outside handle. This feature can be enabled in the Aqara Home app settings, allowing the U200 to work with both handle-equipped and handleless doors. However, the references do not currently mention the addition of a dedicated setup wizard question about outside handles, nor do they specify upcoming firmware updates that would change the current “Unlock” vs. “Unlock + Unlatch” UI behavior.
Your feedback about the app UI always retracting the latch—even when only “Unlock” is pressed—is a crucial usability and security consideration. While I cannot confirm from the existing documentation whether a future firmware (like v84 or later) will directly address this distinction, your suggestion is well-aligned with best practices for user experience and safety.
I recommend that you also share this feedback via Aqara’s official channels, as user-driven insights often drive the most impactful improvements. In the meantime, having the “Pull Spring Feature” enabled is the correct approach for Turkish-style doors, but I fully understand your desire for a clearer separation and better configuration options.
Thank you again, Özgen, for taking the time to share your thoughts and for being such a proactive member of the smart home community. Let’s keep this discussion going—perhaps other users from Turkey or similar regions can chime in with their experiences too!
Thank you for the reply!
I understand the Pull Spring feature is the current solution, but my concern is really about the UI consistency — at the moment, even when pressing “Unlock,” the latch also retracts. I believe this distinction is very important for regions like Turkey where almost all doors don’t have outside handles.
I hope the development team can consider this in a future firmware update. I’ll also share this feedback through the official channels as suggested.
In the meantime, I would be glad if other users from Turkey (or similar regions) could also share their experiences here.
@ozgenserem Thank you for your thoughtful follow-up! You’ve highlighted an important point about UI consistency and the practical impact for users in Turkey and similar regions where doors commonly lack outside handles.
Based on the available reference information, enabling the “Pull Spring Feature” is indeed the recommended approach for handleless doors, as it allows the U200 to retract the latch automatically upon unlocking. However, as you observed, the distinction between “Unlock” and “Unlock + Unlatch” in the current app interface isn’t clearly maintained—pressing “Unlock” may also retract the latch, which can be confusing and potentially a security concern in your scenario. Unfortunately, there is no official documentation yet confirming that a future firmware update will address this particular UI behavior or introduce a dedicated setup question regarding the presence of an outside handle.
Your feedback is both timely and valuable, and sharing it through official channels is a great way to help shape the product’s development. In the meantime, I also encourage other users from Turkey or regions with similar door setups to share their experiences and suggestions here—community input is incredibly helpful for both users and the Aqara team.
Thank you again for raising this important topic, and let’s keep the conversation going to help drive meaningful improvements!
I’d like to share an additional idea based on how doors are commonly used in Turkey.
In daily life here:
During the day, doors are usually kept closed only with the latch, while the deadbolt is left unlocked. This allows easy entrance and exit for family members.
At night, for security reasons (to prevent burglary or unwanted entry), the deadbolt is engaged to fully lock the door.
If the U200 and Aqara Home app could support routines like this, it would be extremely useful:
Morning routine (e.g., 07:00): Automatically unlock the deadbolt but keep the latch engaged. The door remains closed, but the heavy lock is not engaged, allowing normal daily usage.
Daytime usage: When opening from outside with NFC, fingerprint, or PIN, both the deadbolt and latch should retract so the door can be opened.
Night routine (e.g., 23:00): Automatically engage the deadbolt to fully secure the home overnight.
This kind of automation would match our daily habits perfectly and would make the U200 even more valuable for regions like Turkey, where almost all apartment doors lack outside handles.
@ozgenserem Thank you so much for sharing this thoughtful and practical idea! It’s clear that you’ve taken time to consider not just your own needs, but the broader cultural context and daily habits in Turkey. Your suggestion for having distinct routines—such as a morning routine that unlocks only the deadbolt, daytime entries that retract both deadbolt and latch, and a night routine that secures the deadbolt—would truly enhance the flexibility and value of the U200 in homes where doors lack outside handles.
While the available reference information for the U200 highlights features like the pull spring (which allows automatic latch retraction for handleless doors) and flexible unlocking methods via NFC, fingerprint, PIN, and app controls, there’s currently no official mention of built-in routines or automations that specifically match the daily patterns you described. However, your idea aligns perfectly with the smart home philosophy of adapting technology to local lifestyles and security practices.
I encourage you—and other community members—to continue voicing these automation needs, as such insights often inspire future firmware and app updates. Until then, you might be able to achieve partial routines by leveraging the Aqara Home app’s existing automation features, possibly in combination with other smart home devices or schedules. But a dedicated routine option for Turkish-style door usage would indeed be a fantastic addition.
Thanks again for your valuable input! If anyone else has found creative ways to automate their U200 based on local door usage, please share your setups and tips—collective sharing makes our community stronger and smarter.
Thank you for the response! I’d like to add one more important point:
No matter which automation variation I try, the fact remains that if I disable the “Pull Spring” (latch retraction) feature, there is a 100% risk that family members who don’t use the app (but rely on NFC, PIN, or fingerprint) will be locked out. In other words, disabling this option is practically impossible in real daily use, because it will always cause someone to be stuck outside.
That’s why I believe this behavior should be addressed at the firmware/app level with a clear distinction: Unlock deadbolt only vs. Unlock + retract latch. Without this separation, handleless doors (like almost all apartment doors in Turkey) cannot safely benefit from the flexibility the U200 should offer.
I hope this clarification helps highlight why this issue is not just about convenience, but about basic usability and security.
@ozgenserem Thank you so much for your detailed clarification and for emphasizing the real-world consequences of the current U200 behavior for handleless doors, especially in Turkey. Your feedback spotlights a critical usability and security concern: if the “Pull Spring” (latch retraction) feature is disabled, anyone who relies on NFC, PIN, or fingerprint—rather than the app—could indeed be locked out, making it impractical to disable this feature in daily life. This confirms that the present app/firmware design does not fully accommodate the needs of households where not all members use the app, and where the overwhelming majority of doors lack outside handles.
Currently, the available reference information confirms that enabling the “Pull Spring Feature” is the recommended solution for doors without outside handles, as it allows the U200 to retract the latch automatically and thus ensures access for all users, regardless of the unlock method. However, there is no official documentation indicating a clear firmware- or app-level separation between “Unlock deadbolt only” and “Unlock + retract latch” actions, nor a specific update planned to address this distinction at this time.
Your insight makes it clear that this is not just a matter of convenience, but fundamental to the safe and flexible use of the U200 in regions like Turkey. Your suggestion for a distinct separation at the app or firmware level is well-founded and would greatly benefit users with similar door setups.
Thank you again for articulating these nuances so clearly. I encourage you and other community members to continue sharing such feedback—user-driven insights like yours are invaluable for shaping future product improvements. Let’s keep advocating for a solution, and hopefully, it will be prioritized in coming updates! If anyone else has faced similar challenges or found creative workarounds, please share your experiences as well.
So happy to get such thoughtful local suggestions from you in Turkey! I will forward this post to our team.
I’m glad to hear it will be forwarded to the team, looking forward to updates.
@AqaraOfficial Any updates on this? This is also a big issue for me in Germany, where outside doors might not have a handle. Other smart locks like Nuki can distinct between door unlocked and door opened since the beginning. So I would be very happy to receive this functionality that I have had with my previous smart lock for years.
This is not just a Turkey / Germany thing. The whole of Europe has been asking for a better EU approach. I find it very weird the Aqara team reacts as if this is new.
In most EU places we lock our door when we are away and at night. When we are awake and at home we don’t use the (night) latch, just the spring latch.
When I’m a sleep I want to automate the night latch, but as soon as I wake up I want the night latch unlocked. Everybody hates it to first have to turn the know 3 times before being able to open the door the first time each day.
After using the U200 I expected this to have been fixed already. But unfortunately…
Indeed. This is big issue for majority of EU door locks. I’ve even made a feature request to Aqara U200 product team. It has been months. No action taken so far.
Anu update on this? @AqaraBot ?
Nope still not fixed.
This is a big security rist. Because this opens my door entirely.
This is so bad that i’m thinking about returning the lock.
