a { text-decoration: none; color: #464feb; } tr th, tr td { border: 1px solid #e6e6e6; } tr th { background-color: #f5f5f5; }
Hi,
Take this post as a complaint letter about the U200 Lite product. Maybe some others have similar stories/experiences to share.
This has happened two times now, but the last time I wasn’t alone—I was with my partner. Think about my partner as my user, and me as the system provider. I need 100 percent satisfaction in order to convince her that this is the best solution I could find to upgrade our locking mechanism.
This is what happened. Think about the scenario:
You come home, it is −10 °C outside (19 °C indoors). You expect to open the door as always (using your keys), and when trying to open it, you can’t. The lock mechanism inside the door, an Aqara U200 Lite, is blocked and does not let the key open the door. It seems jammed or stalled. It will not give up, and you don’t want to force the key in any direction because it may break. My partner looks at me, and I am calm. I work with electronics, and I say, “Don’t worry, I’ll open the door with the app.” I take my phone, open Home Assistant, and change its status (if I remember correctly, it appears to be locked), and I try to open/close the lock. It fails and starts its failure alarm.
Ok, it is “just” −10 °C outside. We are carrying shopping bags, and the kids are coming to the door too. Ok, I try once more. It fails again and sounds the alarm.
I am the admin in our home system, so the only option is to recalibrate the lock and hope that this solves or forces the motor state. Yes, that worked out. After running the first calibration step, the motor is not jammed anymore. Now I can use the keys once more. Everyone comes in. Everyone carries on with their lives as usual.
Not me. I am worried this may happen again and live in panic that my partner might call me at any time because she cannot open the door anymore and I am not around to help her. I need an explanation. Why could the key not open the door? Why was the motor jammed/stalled?
Can I get the calibration option in Home Assistant at least (over the Matter protocol) in order to remotely rescue her from freezing outside? She will definitely never accept that she is required to use an app to unlock the door after it gets stuck.
I am about to file a product claim due to safety reasons. This resulted well in the end, but I don’t think anyone should go through such an experience, especially when it is advertised as compatible with a mechanical system.
Warm regards,
An almost convince Aqara user.
