I analysed a full week of the lock’s own diagnostic logs (backPanel, 2026-09-12 to 09-19, 98 motor operations). The popular “slow unlocking” symptom on this forum is, at least on my unit, not quiet mode, not turn assist, and not a worn gearbox. The firmware is losing its absolute position reference and then re-discovering the end stop by driving into it at the current limit. I can back every claim below with log lines.
Setup
U200 with keypad, EU profile cylinder, Matter over Thread.
Main/Back panel firmware 3.0.0_0085, front panel 2.5.3_0085, hardware V3.1.
Li-ion pack healthy and stable: 3.96 V/cell, no sag, SoC 92-100% across the whole window.
Symptom
Unlocking (and locking) is sometimes normal and sometimes takes 2-3x longer, with the motor audibly grinding partway through. Random, but frequent. No error is ever reported: the lock does not raise a jam, and nothing appears in Home Assistant over Matter.
1. It is NOT quiet mode or turn assist
All 98 operations in the log were commanded at maximum speed, without a single exception:
final [knob_task_unlock] velocity: 200 x48
final [knob_task_lock] velocity: 200 x50
Door unlock start, velocity:200
Door lock start, velocity:200
The lock never selected a quiet or reduced-speed profile. Scheduled Quiet Mode is off, Unlock/Lock Settings = Fast. So the “movement-following algorithm” explanation given in other threads does not apply to this failure mode.
2. It is NOT a worn or dry gearbox
Normal operations draw 620-990 current units and complete in 3-5 s. The mechanics are fine.
3. What actually happens: the motor is driven past a physical end stop
Duration is strictly bimodal, with nothing in between:
good operations: 3-5 s, 0 hard stalls
bad operations: 8-12 s, exactly 1 hard stall
unlock: 22 of 48 bad (46%)
lock: 17 of 50 bad (34%)
total: 41 hard stalls in 98 operations
A “hard stall” is unmistakable in the log and completely unlike the normal end-of-travel one:
normal end of travel : current 620-990, velocity +-90..+-325, pwm 98-100
hard stall : current 4903-4969, velocity 0, pwm 62-65
Current is pinned in a very narrow band (a saturated limiter), velocity is exactly zero, and PWM is throttled from 100 down to ~62. This lasts 6-8 seconds. Example:
set_target(-14912): position:-1121, i_max:0, break state:stall,
motor_stall: current:4905, velocity:0, pwm:64
check unlock stall position, pos(-1121), delta(11042), angle(332), dir(-1)
Shift position
The commanded target is ~12000-13800 counts (360-415 deg) beyond a point the mechanism physically cannot pass.
4. The calibrated WIDTH is correct; the PLACEMENT is lost
Total Range is reported as exactly 34397 counts in all 71 calibration dumps in the log. It never varies. The physical span measured from the stall points themselves is ~34335 counts:
unlock end stop : pos -1120 .. -1129 (9 counts of spread over a week)
lock end stop : pos 33203 .. 33219 (16 counts of spread over a week)
physical span : ~34335 vs calibrated 34397 -> agreement within ~2 deg
So the travel is calibrated correctly. What drifts is where the firmware thinks that window sits. Immediately before a bad operation the window is offset by ~10100-10950 counts (~300-330 deg). Three times in the week it was off by an entire range - the firmware reported
Unlock Pos 32818 ... Lock Pos 67215
while the physical lock end stop is at 33210. That is a full 34397-count excursion, i.e. the reference frame was lost completely, not merely drifting.
After each hard stall the firmware prints “Shift position” and slides the whole window so the crash point becomes an endpoint. In other words, the lock is using the end stop as a homing switch, and it is homing roughly 40 times a week.
5. Correlated with idle time
gap since previous operation ops with hard stall
< 1 min 56 21%
10-60 min 14 43%
1-6 h 11 55%
> 6 h 9 89%
The first operation after the lock has been idle is very likely to grind. Once it has homed, a burst of consecutive operations is usually clean. Note this is not the 72-hour scheduled reboot (mine ran 09-14 and 09-17 only, while bad operations occur every day).
Why I think this matters beyond my own unit
This drives the motor into a hard stop at roughly 5x normal current, for 6-8 seconds, about 40 times a week - a few thousand times a year. That is exactly the load that cooks grease and shears plastic gear teeth. There are many threads here about U200 gearboxes drying out or stripping after a few weeks or months. I would suggest checking whether that wear is a consequence of this homing behaviour rather than an independent manufacturing defect. If so, replacing gearboxes under warranty will not stop the units coming back.
Questions
- Is the loss of the absolute position reference a known defect in the 0080-0085 branch?
- Is “Shift position” intended behaviour - is the end stop really meant to be used as a homing reference during normal operation?
- Does a manual calibration (mine currently reports manual_cali_flag: 0) anchor the frame more reliably than the automatic one?
- Could auto-lock cycles (auto_lock_mode: 1) be where the reference is lost?
I have the complete log bundle and will send it to support with my device ID. Happy to run any specific test or capture logs with a particular setting changed if that helps narrow it down.
