u200 with hassio is there integration with apple homepod mini matter hub? (no aqara hub)
@dimacheck Hey there! The Aqara U200 door lock is a thread version door lock. To connect it to the Apple Home app (using a HomePod mini as a Matter hub in this case), it should be possible as long as the HomePod mini supports Matter and Thread. Here are some steps that might help if you’re having trouble with the connection:
- Please update the firmware to the latest version in the Aqara Home app .
- Please update the Apple Home hub (HomePod mini) and Apple Home app to the latest version first. The iOS version needs to be above 17.5, then restart the HomePod mini to connect it again .
- Try pulling out the battery from both panels of the U200, scanning the Matter code, and then putting the battery back in to connect to the Apple Home app. If that doesn’t work, try pressing the “Set” button once before scanning the matter code .
- If you still fail to connect, please disconnect any Apple Home hubs that don’t have Matter and Thread, then make sure your HomePod mini (supporting matter and thread) is connected. When the non - Matter/Thread hubs are not in the network anymore, the Apple Home app should be able to add the Aqara U200. After that, you can plug the other HomePods (if any) back in .
Let’s keep the discussion going if you run into any issues or have more questions!
@dimacheck To address your question about integrating the U200 with Hassio using an Apple HomePod Mini Matter hub (without an Aqara hub):
First, regarding compatibility with the Apple HomePod Mini as a Matter hub: The Aqara U200 is a Thread-enabled door lock, and connecting it typically requires a Thread-compatible Aqara hub (such as the M3, G5 Pro, or M100) to function as a Matter controller . If you have a Matter & Thread-enabled border router like the HomePod Mini, it can support the network, but the U200 still needs to pair with an Aqara Matter controller (hub) first .
However, the reference information does not specifically mention integration with Hassio. For details on Hassio compatibility, we recommend checking community discussions or reaching out to fellow users for shared experiences.
If you have further questions or need clarification, feel free to share more details—we’re here to help foster a helpful conversation! For product improvement suggestions, please submit feedback via the Aqara Home App (Profile>Help&Feedback>Customer Service).
Let us know how it goes, and happy troubleshooting!
My Genuinely Honest Take
Yes — it’s theoretically possible to use U200 with HomePod Mini as your Matter/Thread hub, without an Aqara hub.
But in practice, many people face issues: stability problems, commissioning failures, and the need for firmware workarounds.
If you’re doing this in a production / security-sensitive setup (since it’s a lock), I’d be cautious about relying purely on this setup unless you’re okay dealing with occasional flakiness / manual resets.
If possible, getting an Aqara M-series hub (like M3 or M100) might make things much more stable — it’s the more “official” route for Matter provisioning per Aqara.
