Hi Aqara team, Just upgraded one of my U400 from 3.1.1.0 to 3.1.1.4 and noticed that it no longer reports Battery Voltage metrics via Matter (I use Home Assistant). All other values show everything properly. Matter hub shows status Unknown for battery voltage.
I have another U400 with 3.1.1.0 and it reports fine - 7.40 V.
"We’d like to share an update regarding this behavior. Starting with firmware version 3.1.1.4, battery voltage reporting via Matter has been removed.
This is because battery voltage reporting is an optional feature under the Matter standard, rather than a mandatory requirement. Additionally, battery voltage can fluctuate relatively frequently, which may trigger repeated reports and result in unnecessary power consumption. To help optimize the lock’s overall power efficiency, we have therefore decided to discontinue reporting this metric via Matter.
Please rest assured that this change does not indicate a battery issue or affect the normal battery monitoring functionality of your U400. You can continue to monitor the lock’s battery level through the battery percentage/status reported via Matter or the Aqara Home app."
