Everything seems to be working perfectly but the battery level for the lock is not updating in the Hone app. Last night I plugged a portable charger into the USB C port of the lock and let it charge overnight. For some reason, this morning the app said it was only at 71%. So I removed the battery and charged it directly. The battery light turned green so I know it was fully charged and the Aqara app says 100%. But the Apple Home app still shows 71%. I’ve tried to kill the app and relaunch but not fixed. How do I get the lock battery level to sync properly?
Hi there,
Please restart your iPhone and check if it is now synchronized, sometimes the
synchronization will have a bit delay in the Apple Home app due to network
fluctuations or signal strength.
Thanks for the suggestion. Worked like a charm.
Just took a look at the battery level and noticed it was out of sync again in the Home app. Restarted my phone as recommended above and it got things back in sync. But seems odd that a phone shutdown is required to fix this issue. By any chance, is this one of the things being fixed in the next release?
