U400 - Troubleshooting Calibration Issue
Hello All,
This is an initial setup of the U400 with a working Apple Home and Aqara G410 integration. I followed the Aqara Forum recommended order of Apple Home, Aqara App, and Aqara Hub (the G410’s hub). There were hiccups and so I am about to reset and start again.
The biggest issue I saw after the setup was the Aqara App showed “unknown status” for the U400 and repeatedly prompted for calibration. Each time the calibration would complete successfully but the “unknown status” remained. I noticed the calibration didn’t fully lock or unlock but vasilated in the middle. I checked and rechecked the deadbolt’s fit into the door jamb.
One thought I had was that the U400 might expect to see the Aqara-supplied metal strike-plate and plastic receptacle to register the locked and unlocked status. I skipped this in favor of using my door’s existing strike-plate. Does anyone know if this could be a potential cause of my issue?
Thanks in advance for your help.
All the best,
Mickey
The problem I was experiencing had to do with the cable that connects the outer panel to the inner panel. It was making just enough resistance on the bottom of the deadbolt to fail the calibration test. By chiseling a trough just below the deadbolt, the cable no longer impedes calibration.
I have same issue, can you post the fix or email it to me
