U600 Early Review
Smart-Lock-U600
So I bought this on early trial. Didn’t think I would be able to install myself as not great at DIY, but actually the instructions were so clear and the video was good - didn’t have a problem.
Actually will be more confident replacing others. The only problem I had was the circle connecting the door handle was slightly bigger than the hole so had to file a bit off the uPVC door but easy to do.
Once installed, I’ve set up an Apple Home key which works flawlessly, but the easiest way to enter the door is by fingerprint as you don’t even need to get your phone out.
I haven’t set up PIN code entry yet as I we all have fingerprints.
To doublelock the door, you just pull the handle up.
I’ve created a video which is below as well - sorry if this is amateur.
I am very impressed with this door handle and it’s a game changer.
However I would have some improvements/questions still
1 - Still not sure re UK certification - Not sure if this has been published.
2 - I’m hoping the keys are unique to door, but nothing seen on this
3 - Most doors are white in UK - Wish they had made this in white over black
4 - The ideal scenerio would actually be to make this slimmer, get rid of the pinpad and just have fingerprint or just Apple Home. One to consider for next generation.
I had no issue installed in Aquara App. I also had no issue adding an Apple key. Can can see this in home asssitant too.
One problem I do have is that I can’t give each family member an apple key as I need an apple tv - Will get one of these shortly.
I also want to set-up some automations which mean that when the door is unlocked by fingerprint the alarm can partially deactive
A video review is here too
https://youtube.com/shorts/BguayjbyDP4?si=7y7b9AFW4WQ1zAdQ
@ram1t Hey, thanks for sharing this detailed early review of the U600! It’s great to hear the installation went smoothly despite the minor uPVC adjustment — filing down the handle plate is a solid workaround and good to know for other UK installers dealing with standard door profiles.
Really glad the Apple Home Key and fingerprint unlock are working flawlessly for you. The “grab and go” fingerprint access is definitely hard to beat for daily convenience.
A couple of quick thoughts on your points:
  • Apple Home Key sharing: You’re spot on — you’ll need an Apple Home hub (Apple TV 4K, HomePod mini, or HomePod) to share keys with family members. Once that’s set up, each person can get their own key in Wallet. Worth noting that for Home Key to work when devices are out of battery, you’ll need iPhone XS or later with iOS 17.1+ / Apple Watch Series 4+ with watchOS 10.1+.
  • Automation ideas: For fingerprint-triggered alarm partial disarm, once you have your hub in place you should be able to build that automation in Apple Home or Aqara Home depending on how your alarm is integrated. The U600 should expose unlock events you can use as triggers.
Your feedback on color options (white for UK doors), slimmer profile, and a fingerprint/Home Key-only variant are all interesting product suggestions. If you’d like to formally submit these, the best route is through customer support — they can log these for the product team.
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Appreciate the video too — real user installs are always valuable for the community. Keep us posted once you get that Apple TV set up and those automations running
Thanks for sharing this. Great to hear it’s been a game changer.
Besides, here is a topic from the U600 product manager. You may find answers you need here.
