U600 inside locking question
There’s been a lot of discussion about the various ways to get in your house using fingerprints, apple key, codes etc. but I want I know about exiting the house.
I have a child who likes to do a runner so I need to be able to keep the door locked from the inside. Is that possible with the U600?
Unfortunately this isn’t possible with this lock. The interior handle always stays physically connected to the spindle, so it will always operate the latch bolt top allow the door to open. The way it “locks” is by disengaging the exterior handle only.
On top of this, when you install this lock you also remove the cylinder that on a manual door would lock/unlock the ability for the dead bolt and the multipoint from being able to disengage.
I have SEN child and it may be a problem because as far i know cannot be locked from inside which quite disappointing. In this case aqara are not safe whwn you have little kids at all. Once installed any child can passed by pull a handle from inside and open a door? Thats not how smart lock should work, is it?
U600 Smart Lock vs Child Safety
@AqaraOfficial what it going on?
Cheers
I’ve just replied to your other post, but I think ultimately a smart lock alone is not the solution you need as unfortunatly they generally aren’t able to work this way.
Well, thanks for explanation. It looks like this type of device is not for homes like ours.
Kind regards
I am in the same situation with having a SEN child. Take my eye off the front door for a second and it would be like prison break!
I have been looking forward to the U600 for months now and am a little annoyed that such a useful feature is not included.
I always wondered how they would integrate the lift and lock system and assumed it would be through some small but powerful motors. Instead they completely ignored the locking mechanism and just disengaged the outside handle. Genius really.
On the bright side, I’m £200 better off.
Thanks for the explanation. That’s really helpful.
I’m glad I asked as I was seconds away from buying one.
I’m gutted I can’t use the lock in my house as the other features would have been so helpful.
You’re welcome, glad I could help! Having a SEN child also I completely understand where you are coming from as I have been through this. I’m just lucky that mine is now older and it’s no longer an issue for us.
Trying to think it through myself, it does sound like a tricky problem to solve with a smart lock. Having the ability to prevent intruders getting in at the same time as children getting out, whilst still allowing authenticated users access in, and then also maintaining some sort of failsafe or manual bypass for emergencies/malfunction is quite a complex task.
If you really wanted a smart lock still, perhaps you could still do so but add a second manual bolt or door chain higher up on the door? People wouldn’t be able to enter from outside whilst you are home, but it would at least mean you get some smart functionality when you are all away?
