U600 lock reset after incorrectly adding
Hi guys I’m looking for idea how to reset my u600 lock. I have added lock to my old bridge, removed, bought m3 and when I tried to config from the beginning I’m scanning Aqara barcode but won’t connect. Tried to use buttons under battery cover but only resets matter. Found that then inpress and hold both buttons I have voice prompt to reset the lock please verify the password - question what is the password what I’m looking for?
Hello, is Bluetooth enabled on your phone? The initial setup involves connecting without an M3 gateway. Your phone must be connected to your home Wi-Fi network.
Yes it is I have successfully connected and added to Aqara app at the first time, but when I found it they I can’t connect it to HomeKit without matter hub I have removed it and decided to start from the beginning. Now is connected via matter but can’t pair it with Aqara app
Remove the device from HomeKit, add it to the Aqara app, and then use that menu to re-add it to HomeKit. I’m writing this from an Android device, so I can’t provide a screenshot from an iPhone.
The Password is the number you set at the first installation next to your fingerprint.
If you want to reset it , you can also try to use the fingerprint instead of password
Thanks I’ll give a go tomorrow
No luck so far. Deleted from matter and HomeKit.
Both buttons presses and I typed the code but still bonpairing with Aqara app directly only via matter
All done, not sure what I’ve done but insert it without batteries for a while I’ve managed to reset lock and start set up from scratch. Thanks for help
Great ! At least you make it work again ! Have fun with the U600 :enqjol2bgmcitcrmcmgdyz_61:
So far so good, it’s nice, and not thing that I don’t like is that I can’t block opening from inside. That’s the biggest issue with kids at home
You have an M3; set up an audible alert for when a door is opened. This might help reduce your anxiety regarding the children.
Not perfect but always something, 4 yr old may be faster than sound :wink: I’ve upgraded from Yale conexis and their lock I way behind Aqara
