Fitted an Aqara U600 to our front door last weekend and wanted to share how it went. The door has a multipoint locking system, which is common on Irish and UK uPVC and composite doors. Getting the lock to suit the multipoint mechanism was the main thing I checked before buying. The trickiest bit was ensuring the multi point linkages stayed engaged when putting it back together, I accidentally inverted one of them which led me to having to take it all apart again to fix. Also watch out for the little triangle icon on the square bar that joins the two handles through the door, it has to be facing the same direction as the exterior handle.
It’s set up in Apple Home in our Entrance room, alongside the Aqara G4 doorbell, with an Apple TV as the home hubs. First impressions, very positive. Unlocks fast with home key or fingerprint and it has initially passed the spouse test.
Question for everyone: for those of you running the U600 in Apple Home, what automations have actually stuck? I’m thinking of things like auto-locking at night with a Good Night scene, porch lights coming on when the door unlocks after dark.
@fogarty347 Great install write-up, and congrats on passing the spouse test—that’s the real benchmark!
Your multipoint linkage tip is gold; that triangle icon detail on the square bar is exactly the kind of thing that trips people up. Appreciate you sharing the gotchas.
For automation inspiration, while the U600 isn’t specifically detailed in the reference docs, the Aqara Smart Door Lock A100 and D100 give us a solid sense of what’s possible natively in the Aqara Home app—triggers like door unlocked, opened from outside, closed, away mode enabled/lifted, and lock verification failed multiple times are all fair game for building scenes. Since you’re running through Apple Home with an Apple TV hub, you’ve actually got more flexibility combining Aqara’s native triggers with HomeKit’s time/location conditions.
Your night-time ideas are spot-on. A few that tend to “stick” for folks:
- Porch light on + entryway lamp dimmed when door unlocks after sunset (HomeKit’s time condition handles the “after dark” bit)
- Auto-lock confirmation as part of Good Night scene, maybe with a brief hallway light flash as acknowledgment
- Away mode arm when the door locks from outside + no motion detected for 10 min
The U50’s gyroscope auto-lock feature suggests Aqara’s hardware is pretty context-aware, so your U600 likely has similar smarts to build around.
What hub are you using for Thread/Matter—just the Apple TV, or do you have an Aqara M3 in the mix? That changes what you can push to the edge versus cloud-dependent.
