U600 without Lift-To-Lock?
I’ve been looking into the U600 (and historically other loks, like the U200) but I feel like the lock could be made significantly better with remote locking, which isn’t possible on my door due it requiring me to lift the (quite firm) handle to engage the locks.
I know some users have found success by replacing their locking mechanism with the Yale AutoEngage, but I’m a bit lost on exactly what product would work with my door.
My door came with the Winkhaus Thunderbolt Front Entrance Door Lock Kit - Right Hand with 45mm Backset mechanism, which means that the multi-point locks are a specific shape, replacing the whole unit would require finding an AutoEngage (or similar) unit which fits the same shape and position of multi-point locks or modifying my door (undesirable), and getting the right combination is where I start to get confused.
Does anyone have any tips for my specific setup?
Hi, I can tell you just one thing: don’t compare the U200 and U600—they are locks with different functions :smiling_face:
I do hope the U600 does come with the lift to lock option.
As far as I can tell, it does not - UK doors are atypical with the lift-to-engage multipoint locking, and it’s unrealistic for a smart lock to automate this due to the varying amount of force needed from door to door - my door for example needs more force than a simple battery powered motor could provide. The U600 seems to rely on the user to operate the multi-point mechanism. I believe this is how it works:
To unlock the door: it auto-unlatches, then you manually pull down to retract the multi-point locks.
To lock the door: You manually pull up to engage the multi-point locks, then it auto-latches after.
That’s why for me and I assume many others, modifying the door lock mechanism to “auto engage” means that if I leave the house and forget to lock the door, I could the multi-point is already engaged and I could just use the smart lock to latch it.
if you are interested, i had the same problem, i truly dislike the lift lo lock commonly found in the uk.
the solution is a slamshut mortice with a smart lock. GU and Winkhaus seem the only makers that do them unfortunately.
i have a winkhaus av2 and a tuya lock taht i hope replace with a au600 soon. to lock just close the door. to open, having a smart lock with multiple ways of entry means you always have the key with you. (biometrics or pin)
What is the cost like to fit this? Admittedly I have no knowledge in doors or locks lol
I’m interested to see how people get on with this, definitely something I’m going to get in future
i started doing this before smart locks were a thing, probably 10 years ago. so i got a winkhaus av2b fully electronic lock and cost about £600 back then and i have 2 doors. quite an investment.
Using a modern smart lock simplifies things quite a lot, all you need is the slam shut mortice for your door. for UPVC is quite hard to get them at a reasonable price, for wood and composite its easier.
the assembly is no different of any other multipoint lock.
so to calculate the cost find your favourite slam shut mortice, your favourite smart lock and ask any locksmith how much would cost to assemble the lock if you were to supply it
the assembly will be pretty much nothing compared to everything else.
here is a link to an example Gu mortice they call it auto slam
https://upvcspares4repairs.co.uk/gu-secury-auto-slam-shut-door-lock-45mm-backset-20mm-radius-faceplate.html
if you are lucky enough for this mortice to work for you its quite cheap.
for the smart lock i got some of the very first in the market but setting keys or biometrics is a pain.
then got some Bluetooth ones that make adding the keys a lot simpler, but home assistant integration is non existent.
At the time i had the requirement of having a physical key in case i had problems, but never did, so i am hoping that the Aqara U600 integration on home assistant is strong.
