Uk lift and latch locks
Hi , looking to change to aqara lock , how do they function with lift to latch door locks olease
I have the U200 & handle needs to be lifted to allow locking this if of course to do with the locking mechanism of the door which requires the multipoint to be engaged before the lock will turn. The U200 only turns the lock. I am interested to see if the U600 is any diiferent.
Used to use Yale Conexis L2 which could engage without lock being lifted, only reason to change was that the app was not very good for managing access plus home assistant integratation was not great. Aqara much better & integration with home assistant is alot better so high hopes for the U600
I have this problem. Am due to replace my main door and have decided to get a multi lock system but ‘slam to shut’.
There are no handles to push up. Just slam the door and the multi locks fall into place. Then the smart lock just opens it as normal.
I have read about this too & from reading limited information on the U600 sounds like it will be the same unless have slam shut option such as Yale Auto-Engage
Hi Dan , the U600 looks interesting, i may change the multipoint lock to a thumb turn slam lock as Dad struggles to operate the handle at 91 , wonder what the price of rhe U600 will be compared to a nuki with keypad
I can swap my existing multipoint lift to latch to a slam to shut for 300 so will do this and go for a U600 , should save my dad losing his keys and breaking the handle
Our lock allows you to lift the handle to engage the multipoint locking points, while the U600 itself is responsible for locking and unlocking the door, regardless of whether the handle has been lifted. I hope this helps clarify your question.
