In the list of accessories to add, a UK version of the power plug appears, any idea when the product will be available for sale?
In a few months probably, it’s currently in beta tests and it appeared in the app so you could pair it (if you’re a beta tester)
If you see it already, it shouldn’t take that long.
As far as I know started the uk plug beta with the Eu plug H2 … and Eu plug H2 is now on public test! So after this it should be available for everyone. I think 1 or two months
Is it small enough you can put 2 next to each other on a standard UK double wall outlet?
I can’t say for sure how the UK version will fit, but you probably will be able to fit two next to each other - the UK power sockets have more space, and the H2 power plug is much smaller.
I’ve just received an EU version and it’s much better (as you can see compared to two H1 power plugs on the left). But the Schuko/French sockets are usually closer to each other than UK sockets. And in case of this power strip - I won’t be able to fit two H2 plugs (maybe barely, if I used force).
