(UK) Yale Slam Lock for the U600?
Does anybody here have experience with the Yale slam lock for multipoint locks in the UK (or alternatives if there are any)? I’ve heard conflicting opinions on them. I’m also curious about what you paid in total to have them and if you use them alongside an Aqara lock like the u200?
Thanks
@Aftrmth Hey there! Great question — the Yale slam lock for multipoint setups is definitely a topic that comes up a lot in UK smart home circles, and those conflicting opinions you mentioned are pretty common. Some folks love the convenience of auto-locking, while others worry about reliability or compatibility with smart retrofits.
Regarding pairing something like that with the Aqara Smart Door Lock U200 specifically — the U200 is designed for EU mortise locks and certain cylinder types, including UK oval cylinders with emergency function. However, multipoint/slam lock mechanisms are a different beast entirely from standard mortise setups, and the U200 isn’t listed as compatible with those. The U200 works by replacing your cylinder and interacting with the latch mechanism directly, whereas multipoint locks have multiple locking points that engage simultaneously — that’s a fundamentally different mechanical system.
If you’re set on a smart solution for a multipoint door, you’d likely need something purpose-built for that lock type rather than trying to adapt the U200. The U200 excels on standard single-point locks where it can pull the spring latch via the “Pull Spring Feature”, but that’s not transferable to multipoint geometry.
For real-world experiences with Yale slam locks specifically — pricing, installer recommendations, and whether anyone’s found clever workarounds — you’re probably better off tapping into UK locksmith forums or smart home groups focused on multipoint setups. The Aqara ecosystem doesn’t currently have a product in that category.
If you do want to explore whether any Aqara options might work for your door, or need help verifying your lock type against U200 requirements, the support team can walk through your specific measurements and cylinder profile. Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Would love to hear what you end up going with — multipoint smart locking is still a bit of a wild west
