Understanding Energy Monitoring and Autonomy in Smart Homes
Hey everyone, I’ve been diving into the world of energy monitoring lately, and it’s been both fascinating and a bit puzzling. I wanted to share my experience and see if others have encountered similar challenges or have tips to share.
So, here’s my setup: I’ve got a solar panel system on my balcony, which I’ve connected to a smart outlet. This outlet allows me to track the energy being generated by my solar panels. Additionally, I’ve installed an IR sensor on my electricity meter to monitor my energy consumption in real-time. I’ve also set up separate entities for grid consumption and feed-in, which I track using the IR sensor data.
Now, here’s where things get interesting. I’ve noticed that the grid feed-in value is consistently showing as zero, even when my electricity meter is in the negative (indicating that I’m exporting energy back to the grid). This seems a bit odd to me. Furthermore, the PV self-consumption rate in my energy dashboard is showing as 100%, which doesn’t quite add up because there are times when I’m generating more energy than I’m consuming, which should result in a lower self-consumption rate. This discrepancy has got me scratching my head.
I’m also curious about how the autonomy rate is calculated. If the self-consumption rate isn’t accurate, does that throw off the autonomy calculations as well? I’d love to hear if others have encountered similar issues or if there’s a better way to configure the system to get accurate readings.
On a positive note, it’s amazing to see how much energy I’m generating and how much I’m able to rely on renewable sources. It’s motivating me to explore more ways to optimize my energy usage and reduce my reliance on the grid.
If anyone has insights or suggestions, I’d be really grateful! Let’s keep the conversation going and help each other make the most out of our smart home setups. Thanks in advance for your input!
