Understanding GPIO_OUTPUT_ACTIVE and My Journey to Fix It
I’ve been diving into the world of GPIO configurations lately, and I must say, it’s been quite an adventure! I came across this interesting issue with my sensor power pin, and I thought I’d share my journey and findings with you all. Hopefully, this might help someone else who’s stuck in a similar situation.### The PuzzleI have a pin that controls the power flow to my board’s sensors. It’s an active-low pin, meaning it allows power to flow when set to 0. I wrote two blocks of code that, from my understanding, should produce the same result. Here’s what I did:**First Block:**cvoid configure_and_set_sensor_power_pin() { gpio_pin_configure(gpio_dev1, 10, GPIO_OUTPUT); gpio_pin_set(gpio_dev1, 10, 0);}**Second Block:**cvoid configure_and_set_sensor_power_pin() { gpio_pin_configure(gpio_dev1, 10, GPIO_OUTPUT_ACTIVE); gpio_pin_set(gpio_dev1, 10, 0);}From what I gathered, GPIO_OUTPUT_ACTIVE sets the pin’s initial value to 1. But since I’m explicitly setting it to 0 with gpio_pin_set(), I thought both blocks should behave the same way. However, in practice, only the first block worked as expected. The second block didn’t seem to do anything. Why was that?### The Quest for AnswersI did some digging and realized that GPIO_OUTPUT_ACTIVE might not just set the initial value but also influence how the pin behaves in certain configurations. It seems like this flag could be overriding or interacting with other settings in a way I hadn’t anticipated. After some experimentation and consulting the documentation, I found that GPIO_OUTPUT_ACTIVE can affect how the pin’s state is interpreted, especially when combined with other configurations.### The SolutionTo resolve this, I decided to stick with the first block of code for now since it works reliably. I also learned that understanding the specific behavior of these flags in different contexts is crucial. It’s a reminder that even small changes in configuration can have unexpected effects, especially when dealing with low-level hardware interactions.### Final ThoughtsThis experience taught me the importance of thorough testing and documentation, even for seemingly minor changes. It also highlighted how valuable community forums like this are for sharing knowledge and troubleshooting. If anyone has further insights or similar experiences, I’d love to hear about them!Happy coding and tinkering! :rocket:
