🎉 Unleash Your Creativity: Share Your Automation Projects! 🎉
@AqaraBot Do you have help and feedback on the doorbell g4?
@Stian 你好,Stian!关于Smart Video Doorbell G4的帮助和反馈,我这里有一些信息可以分享:
  1. 快速设置:如果你需要添加门铃,可以通过Aqara Home应用来实现。确保你的手机靠近Chime Repeater,然后在应用中选择“Smart Video Doorbell G4”按照指引进行连接。
  2. 重新连接:如果需要重新连接G4门铃,可以长按重置按钮,直到听到重置成功的提示音,然后通过Aqara Home应用重新添加设备。
  3. 常见问题:比如指示灯问题,确认你的指示灯开关已经关闭,如果门铃连接了HomeKit,也要在Apple “Home”应用中同步关闭指示灯开关。
  4. 网络问题排查:确保使用的是2.4 GHz的Wi-Fi网络,避免使用特殊字符在Wi-Fi名称或密码中,并检查路由器的Wi-Fi防蹭网功能和AP隔离设置。
如果你有更具体的问题或者需要进一步的帮助,欢迎随时问,我们的社区也很乐意提供支持!另外,你可以通过Aqara应用中的“帮助与反馈”功能查看常见问题或者直接联系Aqara客服团队。
希望这些信息对你有帮助!:blush:
@AqaraBot thanks for the reply. Do you have any tips on automation on Doorbell G4
@Stian Hello Stian! I’m thrilled to hear you’re interested in automating your Smart Video Doorbell G4. Here are some tips to get you started with automation:
  1. Automation Actions: The G4 doorbell supports various actions that can be triggered as part of an automation setup. These include recording video, playing assigned alarm sounds, enabling or disabling face recognition, and adjusting night vision settings. You can create scenarios like enabling face recognition when motion is detected.
  2. Automation Conditions: You can set conditions such as when the doorbell rings, low battery alerts, or detecting known or unknown faces. For instance, you could set up an automation to play a custom ringtone when a known face is detected.
  3. Third-Party Integration: If you’re using Matter-compatible devices, you can expand your automation possibilities by integrating with other smart home devices. This might include triggering a smart light to turn on when the doorbell is pressed.
  4. Customization: You can upload MP3 ringtones (up to 5 per device) to customize the alert sounds, adding a personal touch to your doorbell notifications.
  5. Community Feedback: Engage with the community to share your automation ideas and get feedback. The more you share and learn from others, the more refined your automation setups will become.
Don’t forget to document your automation projects with visuals and detailed descriptions if you decide to participate in the Aqara Automation Challenge! Good luck, and feel free to share your progress or ask more questions. :blush:
@Stian Hello Stian! I’m glad you found the previous information helpful. When it comes to automating with the Smart Video Doorbell G4, there are several exciting options you can explore:
  1. Facial Recognition Automation: You can enable face recognition to trigger specific actions. For instance, when a recognized family member approaches, you could set the doorbell to play a personalized ringtone or send a notification to your phone.
  2. Night Vision Settings: Automate the night vision mode to switch based on time or ambient light levels. You can set it to always be on, always off, or switch automatically.
  3. Custom Ringtones: Upload your own MP3 ringtones to customize the sound alerts. Keep in mind the file size limit is 5 MB, and you can upload up to 5 ringtones. This can be used creatively, like having different sounds for different visitors.
  4. Integration with Other Aqara Devices: Use the doorbell as part of a larger automation setup. For example, when someone rings the doorbell, you could have your Aqara lights flash or turn on to simulate presence.
  5. Power-Saving Mode: If you’re concerned about battery life, consider setting the doorbell to power-saving mode. It will only wake up with direct interaction like ringing or remote video viewing.
For more complex setups, you might want to integrate with third-party systems like Apple’s HomeKit, Google, or Alexa for even more possibilities.
Hope these tips spark some creative ideas for your automation projects! If you end up creating something cool, don’t forget to share it with the AqaraAutomationChallenge! :blush:
@AqaraBot Which Matter hubs does Aqara offer now and what is coming in the future? What new hubs are coming in 2025?
@Stian 嗨,Stian!:star2:
目前,Aqara 提供的支持 Matter 的设备包括 Hub M3、运动传感器 P2 和门窗传感器 P2。大多数 Aqara 3.0 Zigbee 网关都可以作为 Matter 桥接,除了 G2H pro 之外。如果你对更多设备的信息感兴趣,可以参考我们的产品宣传材料哦。
至于未来的产品,根据我们现有的信息,Aqara 户外摄像头正在开发中,预计将在 2025 年上市。其他新的 Matter 网关计划暂时还没有具体的消息,但请保持关注,接近发布日期时我们会有更多更新哦!
希望这些信息对你有帮助!如果有更多问题或建议,随时欢迎在社区内分享。:blush:
@AqaraBot Doesn’t Camera Hub G5 and Hub M100 matter?
关于你提到的Camera Hub G5和Hub M100,它们在Matter支持方面有一些区别。根据我们的资料,Aqara Camera Hub G5 Pro确实支持高级的Matter桥接功能,可以同步Aqara特定的场景和信号到Matter生态系统,比如Home Assistant。而对于Hub M100,目前并没有详细的信息表明它支持Matter。
如果你对某个特定设备的Matter支持有疑问,建议查看官方的产品页面或者宣传材料获取最新的确认信息。希望这些信息能帮到你!如果有更多问题,社区随时欢迎你的发言。:blush:
祝你在Aqara社区玩得开心!
@AqaraBot Thanks for the answers above, they are in Chinese, can you translate them into English?
@Stian @Stian Hi Stian! :star2:
Absolutely, let me translate that for you:
Currently, Aqara offers devices that support Matter, including the Hub M3, Motion Sensor P2, and Door and Window Sensor P2. Most of Aqara’s 3.0 Zigbee gateways can serve as Matter bridges, except for the G2H Pro. If you’re interested in more device information, I recommend checking our product promotional materials.
As for future products, based on our current information, an Aqara outdoor camera is under development and is expected to be released in 2025. There are no specific details on other new Matter gateways yet, but stay tuned for updates as we get closer to the release dates!
Regarding the Camera Hub G5 and Hub M100, the Aqara Camera Hub G5 Pro does indeed support advanced Matter bridging capabilities, allowing Aqara-specific scenarios and signals to sync with the Matter ecosystem, like Home Assistant. However, for the Hub M100, there isn’t detailed information confirming Matter support at this time.
I hope this helps! If you have more questions or suggestions, feel free to share within the community. :blush:
Have a great time in the Aqara community!
@AqaraBot I have a Magic Switch S1E, which Aqara devices does it support? and which Mars Tech devices can I connect?
@Stian 你好,Stian!关于你的问题,Aqara Magic Switch S1E可以支持多种Aqara设备。根据我们的FAQ,它可以与灯具、窗帘、开关和插座等设备关联和控制。不过需要注意的是,Magic Switch S1E本身是一个Wi-Fi设备,可以独立工作,但如果你要与Zigbee子设备关联,则需要通过Aqara Hub进行配对。
至于Mars Tech设备,由于我们没有关于该品牌的具体信息,我建议你查看设备是否是Matter-compatible设备。如果是这样,你可以尝试通过Aqara Home应用添加这些Matter设备。详细步骤是:打开Aqara Home应用,进入“主页”,点击右上角的“+”图标,选择“添加设备”,然后选择“Matter Device”并按照屏幕上的说明完成设置。
希望这些信息能帮助到你!如果还有其他问题,欢迎随时提问哦!:grin:
@AqaraBot What automations do you recommend on the Switch?
@Stian Hey Stian! :blush:
When it comes to automations with your Aqara Magic Switch S1E, the possibilities are as magical as the switch itself! Here are some fun and practical automation ideas you might consider:
  1. Lighting Control: Use the Magic Switch to control different lighting scenarios in your home. You can set automations like “If the middle button is pressed, then dim the lights to 50% for a cozy evening vibe.”
  2. Curtain Control: Automate your morning routine by linking the switch to your smart curtains. For example, “If the left button is turned on, then open the curtains to let in the morning sun.”
  3. Energy Saving: Set up an automation to turn off all connected appliances when you leave the house. Something like “If the right button is turned off, then shut down all connected devices” can help save energy.
  4. Security Enhancements: Enhance home security by integrating the switch with sensors. For instance, “If the door sensor is triggered, then turn on all lights” for added safety.
  5. Custom Scenes: Create custom scenes for different moods or activities. You could have an automation like “If the switch is clicked three times, then activate movie mode,” dimming the lights and closing the curtains.
Remember, the key to great automation is creativity, so feel free to mix and match actions to suit your lifestyle. And don’t forget to share your setups in the community for a chance to win some cool prizes! :rocket:
Happy automating! If you have more questions or need further assistance, feel free to ask. :star2:
@AqaraBot Do you have any information about the new MagicPad S100?
@Stian Hi Stian! :blush:
As of now, I don’t have any specific information about the MagicPad S100. It seems like this might be a new or upcoming product that hasn’t been officially detailed in the available resources yet. However, I can assure you that Aqara consistently updates their product line, so it’s worth keeping an eye on the official Aqara announcements or the community forums for any upcoming news.
In the meantime, feel free to explore our existing products like the MagicPad S1 Plus, which is packed with features and widely supported in the smart home setups. If you have any more questions or need assistance with current Aqara devices, don’t hesitate to reach out! We’ll make sure to keep the community informed as soon as more details are available.
Happy automating and stay magical! :star2:
@AqaraBot Who is the CEO of Aqara?
@Stian 嘿,Stian!关于Aqara的CEO,目前没有具体的信息对外公布。不过,可以告诉你,Aqara是由Lumi United Technology Co., Ltd.创立的,他们在智能家居领域可是大有作为的哦!如果你对Aqara的更多信息感兴趣,欢迎随时在社区发问,我们都会尽力帮你找到答案的!:blush:
@AqaraBot Do you have a simple security system for elderly people or people who don’t have a smartphone?
