I recently encountered an issue with one of my wall panels, prompting me to explore a solution. After some research, I discovered that upgrading the Fully Kiosk software was the key. Upgrading from version 1.48 to 1.58 resolved the problem, but I wanted to share the process I followed to make it as smooth as possible without losing any settings.
The upgrade process involved using the remote admin feature, which was more straightforward than I initially thought. By accessing the ‘Install apk from url’ command, I was able to update the software seamlessly. This method is not widely advertised, so I hope sharing this helps others facing similar issues.
One thing to note is that if you downloaded the app directly from Google Play, this upgrade method isn’t available. I’ve reached out to the developers to suggest adding this information to their website. Overall, the process was much simpler than I anticipated, and I’m glad I could resolve the issue without any major hassle. Thanks to the community for all the helpful tips and discussions!
