Upgrading to OpenHAB 2.5.8 - A Smooth Experience
I recently upgraded my OpenHAB setup to version 2.5.8, and I must say, the process was surprisingly smooth! For those of you considering an upgrade, I wanted to share my experience and some tips that might help you along the way.
My Setup Before the Upgrade
Before the upgrade, I was running OpenHAB 2.5.0 on a Raspberry Pi 3 Model B with a modest 1GB of RAM and a 32GB SD card. My setup included a mix of Zigbee, Z-Wave, and some legacy devices. I was using the following configurations:
  • Bindings: Modbus, ntp, influxdb, transformation-javascript
  • Persistence: InfluxDB for time-series data
  • Dashboards: Grafana for visualizing sensor data
The Upgrade Process
  1. Backup First: Always start with a backup. I used the built-in snapshot feature in OpenHAB to create a backup of my current configuration. This gave me peace of mind knowing I could revert if something went wrong.
  2. Updating OpenHAB: I followed the official OpenHAB documentation for upgrading. Since I was using the Raspberry Pi, the process involved updating the system packages and then pulling the latest OpenHAB image.
  3. Post-Upgrade Checks: After the upgrade, I checked the logs to ensure everything was running smoothly. The most significant change I noticed was improved performance, especially with the influxdb persistence.
Tips for a Successful Upgrade
  1. Check Compatibility: If you’re using third-party add-ons or custom configurations, make sure they’re compatible with the new version.
  2. Incremental Updates: If you’re upgrading from an older version, consider doing it incrementally rather than jumping multiple versions at once.
  3. Test Automation Rules: Some automation rules might behave differently after an upgrade. Test them thoroughly to ensure they’re working as expected.
Challenges I Faced
  • Configuration Migration: Some configurations, especially custom rules, required tweaking to work with the new version. I recommend reviewing your configuration files post-upgrade.
  • Log File Issues: I encountered a malformed SQLite database error, which I resolved by deleting the old database and letting OpenHAB recreate it.
Upgrading to OpenHAB 2.5.8 has been a positive experience. The improved performance and new features make it well worth the effort. If you’re hesitant about upgrading, I highly recommend giving it a try!
Let me know if you have any questions or tips for upgrading, and feel free to share your own upgrade experiences in the comments below! :slight_smile:
