Use cases for temperature and humidity sensors with a mini split
Hello all,
I have had a temperature and humidity sensor through Aqara for some time. The best use case I could come up with was to put it in my enclosed sunroom to let me know if and when it was time to turn on my Senville mini split. Does anyone know of a work around or a better use case for these types of sensors? Let me know how you have used yours!
You can use them in the bathroom to start a certain music playlist on a speaker once it reaches the humidity level you set.
@jakediliegro two ideas, one for the sunroom and one building on eduardo’s bathroom suggestion:
Close the loop on the mini split. Right now the sensor tells you when to turn the mini split on, and then you do it. If your hub has an IR blaster (the M2 and M3 do), you can teach it the mini split’s remote and let the sensor turn it on itself: sunroom above X degrees, cool; below Y, heat or off. Leave a few degrees of gap between the on and off points so it isn’t flipping back and forth all afternoon. One catch: IR is one-way, so the hub never knows if the unit actually heard it. Keep the sensor in the loop to confirm the temperature is really moving.
Bathroom humidity: don’t use a fixed number. This one bit me. I tried a fixed “humidity above X% = shower running” trigger for a bathroom fan, and every threshold I picked broke within about a month, because the room’s normal humidity drifts with the seasons. What finally worked was comparing against a rolling baseline: “shower = humidity is 6+ points above what this room has been sitting at lately.” It hasn’t needed retuning since.
A couple of other easy wins: a sensor in a closet or basement that alerts you when humidity creeps up (mold warning), and one near pipes in an unheated space that warns you before they can freeze.
Small correction to my earlier reply: the shower flag doesn’t run a bathroom fan. It holds the bathroom lights on so the motion timer can’t turn them off mid-shower. I wrote up how the detection works (and the two versions that failed first) here: Shower detection that finally stopped breaking: a moving baseline, and the sensor was in the wrong spot
