Used Aqara FP400 to improve air quality issue
I have used Aqara FP400 in handling air quality issue. I have set the automation when the occupancy count reaches 6 or more and stays for certain time then adjust the temperatures (HVAC in fan mode once temperature reached desired level) and also keep air circulating. And also to turn the air purifier on once the count reaches 0. Will keep exploring more ways to use this product.
Will definitely recommend this product.
I also use FP400 presence for climate automations in Home Assistant, with the AC controlled through an API. One detail that would help others adapt this is whether your HVAC fan brings in outdoor air or only recirculates indoor air. The EPA’s indoor air quality overview separates ventilation from filtration, so I’d treat occupancy as a trigger, not an air-quality measurement.
Is running the purifier only after the room empties mainly a noise decision? If it supports different speeds, a quieter occupied mode and a stronger empty-room mode could be worth testing. That would avoid making zero occupancy the only opportunity for filtration, while a separate air-quality reading could help check whether the strategy is actually improving the air.
Nice way to use the occupancy counter. Hadn’t thought of this!
My HVAC pulls the fresh air from out side. My air purifierfully manual control with a dial to turn ofd, low, medium and high speeds. so I have connected that to smart outlet and use that to turn it on and off (always set at medium).
