Using Aqara cameras with Apple Home and Home Assistant — what works reliably?
Hi! I’m gradually bringing more of my home into Home Assistant, while keeping Apple Home easy to use for the family. I have Aqara G3 and G2H cameras and would like to use them in both systems.
For those doing this, what setup has been reliable over time? I’d like to open a live view from a Home Assistant dashboard without losing the camera features we use in Apple Home.
I’m especially interested in how quickly the picture starts, whether two-way audio works, and whether the cameras reconnect on their own after a network interruption. If you’re using go2rtc or another bridge, has it needed much maintenance?
Please mention which camera model and connection method you’re using. I’m still working through the setup, so practical experiences would be really helpful.
Not a camera, but a nearby data point: my Aqara doorbell (SVD-C02) runs in both Apple Home and Home Assistant at the same time. Apple Home has been flawless in daily use, and the picture starts quickly when I open the live view. Two-way audio works, though the built-in speaker is on the quiet side - visitors at the door sometimes have trouble understanding me.
Following along for the G3/G2H specifics.
Thanks, that is useful. How have you connected the SVD-C02 to Home Assistant while keeping it in Apple Home? Are you using go2rtc or another integration? Also, does two-way audio work in both apps, or only in Apple Home? I’m trying to separate what works in each system before choosing a setup for the G3/G2H.
One correction to my own post above, stated more precisely: one drawback is the doorbell speaker - visitors at the door often have trouble understanding what I say. I should have put it that way instead of summarizing it as “two-way audio works”.
On your questions about the exact connection method (go2rtc or another integration) and whether audio is available in Home Assistant too, I want to double-check my own setup before answering - I would rather not guess. I will follow up here.
Following up with what I can confirm from daily use on the Apple Home side: the SVD-C02 runs flawlessly in Apple Home, and recording works. Since one of the recent firmware updates, the red ring on the doorbell lights up while it is recording - a helpful visible indicator.
On the exact Home Assistant integration method and per-app audio behavior I can’t confirm the details at the moment, so I’d rather not guess.
Have you tried the iPhone/iPad/Desktop app “HomeCam”. It displays all Apple Home cameras “Live” feed. It’s quick with no delays.
You cut out Apple Home and Home Assistant from the equation. Run HomeCam on any display and watch all your camera feeds. Take the load off Apple Home and Home Assistant and let them be used for other stuff.
Apple Home can only run one camera at a time “Live” and Home Assistant will choke out if you try doing the same.
I have four G100 cameras, and they linked to Apple HomeKit without issue—simply scan the tag on the device and it connects. Apple HomeKit only supports 1080P video which is a bummer. If Apple added 2K video support (the camera’s native resolution) it would be perfect.
Thanks everyone — this thread already answers a lot of the trade-off.
The pattern that has worked best for me is to let Apple Home own the camera through HomeKit Secure Video, and use Home Assistant mainly for the automations and sensors around it, rather than trying to pull the same live stream into both systems at once. That is where I have seen the fewest dropouts: HSV gives you the timeline, person/vehicle detection and iCloud recordings in one place, and you avoid the one-live-stream-at-a-time limit that @srl77411 mentioned.
Two practical points that made the biggest difference for me:
  • Keep the home hub solid: an Apple TV or HomePod wired by Ethernet if you can, and the camera on a stable 2.4 GHz signal with a decent RSSI. Most of the ‘slow to open’ moments I have seen were Wi-Fi or hub related, not the camera itself.
  • Decide what matters more per camera: with the G100, as @shanstewart said, you get the convenience of HomeKit but capped at 1080p, while the Aqara app keeps the native 2K. For a front door or entrance I prefer HSV; for a spot where detail matters, I keep the Aqara view.
One caveat from @jbalm0’s doorbell experience is worth keeping in mind too: two-way audio can be much quieter than expected, so test it from outside before relying on it to talk to a visitor.
For Home Assistant, I would start with one camera, check live-view start time and recording reliability for a few days, and only then add the next one — adding several at once makes it much harder to tell whether a problem is the camera, the network or the hub.
@shanstewart Welcome to the forum!!!
