Hey everyone, I’ve been diving into Home Assistant automations lately and came across a fun challenge: using random RGBW colors to add some variety to my LED lights. I thought I’d share my journey and solution in case others are curious or running into similar issues!
The Goal
I wanted to create an automation where my RGBW LED lights change to a random color every time they turn on. It’s a simple idea, but I ran into a few hiccups along the way.
The Setup
I started by setting up random number sensors for red, green, blue, and white channels. The idea was to use these values directly in the light.turn_on service call. Here’s what my initial configuration looked like:
yaml
action:
- service: light.turn_on
data:
brightness_pct: 20
rgbw_color:
- random_red
- random_green
- random_blue
- 0
But when I tested it, I got an error: expected int for dictionary value @ data['rgbw_color']. Hmm, that wasn’t right. I knew the sensors were returning integer values, so why the error?
The Problem
After some digging, I realized that the service call was expecting actual integers, not the names of the sensors. So, while random_red held a value like 128, the service didn’t recognize it as a number—it saw it as a string.
The Solution
I remembered that Home Assistant has a template service that can evaluate expressions. So, I decided to use input_number entities instead of sensors and then use template to convert them into integers. Here’s how I adjusted my configuration:
yaml
action:
data:
brightness_pct: 20
rgbw_color:
- ‘{{ states.input_number.random_red.state | int }}’
- ‘{{ states.input_number.random_green.state | int }}’
- ‘{{ states.input_number.random_blue.state | int }}’
- 0
This worked perfectly! The template service evaluates the sensor values as integers, and the lights now cycle through random colors beautifully.
Tips for Others
If you’re looking to do something similar, here are a few tips:
- Use Input Numbers: They’re perfect for this kind of dynamic automation since you can easily adjust their values.
- Leverage Templates: The
templateservice is incredibly powerful for evaluating expressions and converting data types on the fly. - Test Incrementally: Start by testing each part of your automation separately. For example, ensure your random number generators are working before integrating them into your lights.
Wrapping Up
This project was a great learning experience. It taught me more about how services handle data types and how to creatively use templates to overcome limitations. Plus, it’s added a nice touch of randomness to my home’s ambiance!
If anyone has other creative automation ideas or runs into similar issues, I’d love to hear about them. Happy automating everyone! ![]()
