Hi there and welcome to the forum.from what I know the HomePod mini doesn’t have UWB support.you will need an Apple TV 4K 2/3 gen for that option to work and also you need to activate your location on you iPhone for that too.
Do you need one of this devices:
Apple TV 4K (3rd generation — Wi-Fi + Ethernet model) — Note: The cheaper, Wi-Fi-only 3rd gen Apple TV 4K lacks an Ethernet port and also lacks a UWB chip, so avoid that specific model if you are buying one for this.
HomePod (2nd generation) — The full-sized, standard HomePod 2nd gen does include a UWB chip (unlike the HomePod mini).
I think UWB on HomePod doesn’t matter, the UWB on those devices is used to detect if you’re putting your iPhone close to the HomePod (it opens a window with current song on your iPhone).
The iPhone/Apple Watch has to have UWB, as it’s the device that needs to communicate with the lock.
Since Tap to Unlock works but Unlock on Approach doesn’t, it sounds like the issue may be with the UWB/proximity feature rather than the lock itself. I’d check that UWB and Express Mode settings are enabled on the iPhone and that the U400 has the required permissions in the Aqara and Home apps. If the UWB light never comes on, I’d also contact Aqara support since the hardware may need to be checked.
Yeah for thread hubs but not for UWB only the HomePod second gen that big one is compatible and as I mention the Apple TV 4K with Ethernet connection you could call apple and ask them.if the U400 works perfectly without UWB then is not the U400 issue is on apple side
As I mention I didn’t know ether I just search on internet about but to better know more you should check with apple as they will tell you exactly if the HomePod mini is compatible or not.from what I read those 2 apple devices compatible with UWB makes some.here what I found about how apple devices uses UWB
@samyo14
Even though your HomePod mini acts as a Thread border router to let the lock communicate, the actual spatial calculation for UWB “Unlock on Approach” requires a hub with a UWB radio to map out distances and angles. Without a UWB-enabled hub anchoring the Apple Home ecosystem, your iPhone 16 Pro Max’s UWB chip has nothing to “talk” to in the room to trigger that proximity light.
Aqara’s official U400 page explicitly lists HomePod mini as a supported Thread-enabled Apple home hub for UWB unlock with a compatible iPhone or Apple Watch. That means replacing the mini is not a documented requirement for this feature. @samyo14, I would keep the current hub while support checks why Unlock on Approach fails even though tap-to-unlock works.
Yes you are right the HomePod mini have the first gen UWB but from what I read that can only be used for apple keys not for Auto Unlock by approaching the door my be I am wrong my be I am not that is why @samyo14 you need to ether contact Aqara support and ask them about the compatibility or apple themselves.since we do not have such option on EU regarding UWB we only can speculate but the best answer you can receive is from Aqara support as they know better.
So support had me add the lock without the hub into a new home and UWB works just fine. However, the lock isn’t accessible in the Home app - most likely because it needs a hub…
