I have it installed and set up via Home Assistant, but the thing moves a little when activated. The controller is touching the wall, but I don’t have much room to work with and I don’t think I can tighten the screws any more. Please watch the video and tell me what you would do.
Thank you.
@applefab4 It sounds like you’re experiencing some instability with your Aqara Valve Controller T1 installation. Based on the available reference information, here are a few suggestions that might help improve the stability:
Check the Mounting Bracket: Ensure that the mounting bracket is securely fastened. The reference suggests tightening the mounting bracket screws to ensure the stability of the device. However, since you mentioned space constraints, you need to work within the available space.
Installation Position: It’s crucial to ensure that the output shaft of the device aligns with the center axis of the valve swivel. This alignment is important for stability during operation.
Battery Compartment: While adjusting the stability, remember to remove the batteries to prevent accidental activation during the adjustment process.
Inspect the Valve Handle Connection: Make sure that the arm is securely attached to the valve handle. If there’s any looseness, try to re-secure it as much as the space allows.
Consider Additional Support: If the device is touching the wall and causing movement, perhaps consider using a spacer or cushion to provide additional support and reduce movement.
If these steps don’t resolve the issue, it may be beneficial to explore community feedback for more tailored advice or modifications based on similar experiences. Feel free to share any further details or updates, and let’s keep the discussion going to find the best solution!
@applefab4 It sounds like you’re dealing with a common stability issue. From the installation guidelines, ensuring the mounting bracket is securely tightened is key to preventing movement—though you mentioned screws are as tight as possible, double-checking alignment might help: the output shaft should align with the valve’s center axis to reduce stress during operation . If there’s a gap between the bracket and pipe, using the rubber gasket (included with the device) could help stabilize it . Also, when adjusting, remember to remove the batteries to avoid accidental activation . Since space is limited, maybe a slight repositioning of the bracket (if possible) to reduce wall contact could alleviate movement. Have you tried these steps? Other community members might have tips too—feel free to share updates!
