Vera Edge Security Alert Resolution
I recently encountered an issue with my Vera Edge controller where it kept showing an alert stating, ‘No security device has been installed.’ Despite having a deadbolt and thermostat connected, the alert persisted. This was quite puzzling and a bit concerning, as I wanted to ensure my security setup was fully functional.
After some research and reaching out to the community, I discovered that the Vera Edge sometimes requires a manual check of connected security devices. I decided to go through the setup process again, ensuring that all devices were properly paired and recognized by the system. It turned out that the deadbolt needed a firmware update, which I applied through the Vera app.
Once the update was complete, I reconnected the deadbolt, and the alert finally disappeared. It was a bit of a hassle, but the sense of relief knowing my system is secure was worth it. If anyone else is facing similar issues, I’d recommend checking for firmware updates and ensuring all devices are correctly paired. Happy troubleshooting! :rocket:
