Hi everyone, I’m reaching out to see if anyone has encountered a similar issue with Vera’s scene automation. I’ve been using Vera for a while now, and I’ve set up a scene called “Armed Away” which turns on several sets of flood lights and is supposed to turn them off after 5 minutes. The lights turn on as they should, but they never turn off automatically. If I run the scene manually, everything works perfectly—the lights come on, stay on for 5 minutes, and then turn off. However, when the scene runs automatically when the panel is armed away, the lights never turn off. I’ve tried troubleshooting by checking the logs, updating the firmware, and even manually running the scene to ensure it’s working correctly. I noticed that when I arm the panel remotely using the virtual panel, the Vera engine reloads, which might be causing the issue. I’ve attached a portion of the log for reference. If anyone has any ideas or suggestions on how to resolve this, I’d greatly appreciate it. Thanks in advance for your help!
