VeraLite Network Issues and Solutions
I recently encountered an issue with my VeraLite device, and I wanted to share my experience in case it helps someone else. After setting up my VeraLite, I noticed that the network light was flashing very quickly, and I couldn’t connect to it. This was frustrating, especially since I had just started exploring the device’s capabilities.
I tried several troubleshooting steps, including power cycling the VeraLite, resetting it, and even deleting and re-adding the device. None of these worked initially. I reached out to the community for advice, and someone suggested checking the firmware version. It turned out my VeraLite was running an outdated firmware, which was causing the network issues.
After updating the firmware, the network light stabilized, and I was able to connect without any problems. This experience taught me the importance of keeping firmware up to date, even for devices that seem to work fine initially. I hope sharing this helps others avoid the same frustration! :blush:
