Vibration sensor Automations Aqara + HAOS
Hi,
What other uses can a vibration sensor be made with Aqara + HAOS?
Thank you,
@jcgiraldoh1 Hey there! Great question — the Aqara Vibration Sensor is pretty versatile beyond the obvious security setups.
From what we know, it can detect vibration, tilt, and drop events, which opens up quite a few creative angles with Home Assistant OS. Think: monitoring if your washing machine or dryer has finished a cycle (vibration stops), detecting if a mailbox or delivery box was opened/closed, keeping tabs on a garage door position via tilt, or even catching if someone moves a laptop or safe unexpectedly.
Since it communicates over Zigbee, it’ll play nicely with your Aqara Hub and HAOS automations — and the local automation execution still works even if Wi-Fi drops, as long as your Hub stays powered.
A few practical tips: sensitivity is adjustable through the Aqara Home App, which helps fine-tune for different surfaces and use cases. Also worth doing an effective range test at your placement spot before committing — single-press the reset button and listen for the Hub voice prompt.
What kind of setup are you thinking about? Would love to hear what you’re automating — might spark some more ideas
