Would the Aqara vibration sensor work for detecting water flowing through my main water line? I want to use this to detect extended water use or general leaks in the system. Don’t know if the sensor can be strapped to the water pipe.
@sdegonge The Aqara Vibration Sensor is designed to detect vibration, tilt, and drop, and it can be quite versatile in various applications. However, using it to detect water flow through a main water line might not yield the most reliable results. The sensor is not specifically designed for detecting continuous flow in pipes, as its primary function is to trigger events based on vibration or movement.
You can definitely try strapping the sensor to your water pipe to see if it picks up vibrations from water flow, but keep in mind that its sensitivity might not be precisely tuned for such an application. Moreover, the sensor triggers a “vibration detected” event once a minute, and it won’t trigger again for the next minute even if the vibrations continue. This could limit its effectiveness for continuous monitoring of water flow or leaks.
For detecting leaks or monitoring water usage more accurately, you might want to consider other sensors specifically designed for water detection or flow monitoring. These might provide more precise and reliable data for your needs.
Feel free to experiment and share your findings with the community! If you have any more questions or need further assistance, don’t hesitate to ask.
@sdegonge Thanks for your question! Regarding using the Aqara Vibration Sensor to detect water flow in the main water line, the reference information doesn’t specifically mention this use case. Generally, the Aqara Vibration Sensor can detect vibration, tilt, and drop . For installation, it can be placed directly or stuck to a surface , but strapping to a pipe isn’t explicitly outlined.
Since we don’t have specific data on water flow detection, you might want to connect with other community members—they may have tried similar setups and can share practical insights! If you have ideas for product improvements, feel free to submit feedback through the Aqara Home App’s customer service channel.
Hope this helps, and we’d love to hear how it goes if you give it a try!
@sdegonge The Aqara Vibration Sensor is designed to detect vibration, tilt, and drop . While the reference information doesn’t specifically mention detecting water flow through a pipe, its vibration-detection function might potentially pick up vibrations from water flow.
For installation, the sensor can be placed directly in the desired position or stuck to a surface after removing the protective film . If you plan to strap it to the pipe, you could first test the location: after linking the sensor to the Hub, press the reset button on the sensor at the pipe location. If the Hub prompts “normal link confirmed,” the location is suitable; otherwise, adjust and try again .
Since every setup is unique, your experience with strapping it to the pipe and detecting water flow would be valuable to share with the community! If you try it out, feel free to update us on how it works—we’d love to hear your insights.
@sdegonge The Aqara Vibration Sensor is designed to detect vibration, tilt, and drop , but the reference information does not specifically mention its use for detecting water flow in a main water line or strapping it to a water pipe.
Since this specific use case isn’t covered in the available information, we can’t confirm its effectiveness for this purpose. However, the community might have members with similar experiences—feel free to share your setup if you try it, as it could help others!
If you have suggestions for improving the sensor’s functionality or need further clarification, please contact Customer Service Team by Aqara Home App (Profile>Help&Feedback>Customer Service) or scanning the QR code:
Hope this helps, and looking forward to hearing more from your smart home journey!
