Vibration Sensor Setup and Troubleshooting for Spiral Staircase Monitoring
Hi everyone, I wanted to share my experience setting up vibration sensors for monitoring my spiral staircase. It’s been a bit of a journey, but I’ve learned a lot along the way!
I initially looked into vibration sensors for my spiral staircase because motion sensors were tricky to position without false triggers. I started with the Aqara vibration sensor, which worked well initially. However, I encountered an issue with its cooldown period—it wouldn’t trigger again for 60 seconds, which wasn’t ideal for my setup.
After some research, I tried the Moes vibration sensor, which I heard was more flexible. I was happy to find that it’s compatible with Hubitat, which is the ecosystem I use. The Moes sensor allowed me to set a shorter cooldown period, which was exactly what I needed. I adjusted the driver settings to reduce the inactive time after a trigger, making it much more reliable for my staircase monitoring.
Here are a few tips I learned during this process:
  • Check Compatibility: Always verify that the sensor is compatible with your hub or ecosystem. I was lucky with the Moes sensor, but it’s something to double-check.
  • Adjust Settings: Don’t hesitate to tweak the sensor settings. The default cooldown might not suit your specific use case, and most sensors allow for adjustments.
  • Placement Matters: For spiral staircases, strategic placement is key. I found that placing sensors on the first and last steps worked best to avoid missed triggers.
I hope this helps someone else who’s looking to set up vibration sensors for similar purposes. It’s been a learning experience, but it’s rewarding to have a reliable system in place!
Best regards,
