Virtual Thermostat Setup for Multi-Zone Heating
Hey everyone, I’m excited to share my experience with setting up a virtual thermostat using deconz for my home’s heating system. I’ve been using deconz for a while now, and it’s been a reliable solution for automating my smart home. However, I recently faced a challenge when trying to extend its functionality to multiple zones in my house. Let me walk you through my journey and how I overcame the hurdles.
The Goal
I wanted to maintain a consistent temperature across several zones in my home using zigbee relays and temperature sensors. The idea was to avoid using wall-mounted programmable thermostats and instead rely on a centralized system. I’ve successfully used deconz rules in the past to control an electric heater, but scaling this to multiple zones presented a new set of challenges.
The Challenge
Each zone required its own temperature sensor, and manually updating the desired temperature across multiple rules was cumbersome. I envisioned using a virtual CLIPTemperature sensor to set the desired temperature once and have it apply across all zones. But I wasn’t sure if deconz allowed referencing a sensor value within a rule condition. This was crucial because it would determine if I could dynamically adjust the temperature without rewriting each rule.
The Solution
After some research and experimentation, I discovered that deconz does support referencing sensor values in rule conditions. This meant I could create a single virtual sensor for the desired temperature and have all my heating zones reference this sensor. Here’s how I implemented it:
  1. Virtual Sensor Setup: I created a virtual CLIPTemperature sensor in deconz. This sensor acts as the master control for the desired temperature across all zones.
  2. Rule Configuration: For each zone, I set up a rule that monitors the virtual sensor’s value. When the current temperature in a zone drops below the desired temperature, the rule triggers the heater to turn on. Once the desired temperature is reached, the heater turns off.
  3. Dynamic Adjustment: By updating the virtual sensor’s value, I can adjust the desired temperature for all zones simultaneously without touching individual rules.
Benefits
This setup has been a game-changer for me. It provides a centralized way to manage heating across multiple zones, making adjustments quick and efficient. Plus, it keeps my system organized and scalable for future expansions.
Tips for Others
If you’re considering a similar setup, here are a few tips:
  • Plan Your Zones: Clearly define each heating zone to ensure optimal coverage.
  • Test Individually: Before linking everything together, test each sensor and relay individually to catch any issues early.
  • Leverage Virtual Sensors: They offer a flexible way to centralize control without complicating your setup.
Conclusion
I’m thrilled with how this system has streamlined my home’s heating automation. It’s a testament to how powerful deconz can be when you push beyond its basic features. If anyone has questions or needs help setting something similar up, feel free to reach out! Happy automating! :blush:
