Visualizing Home Temperature with Heatmaps
Hey everyone! I wanted to share my journey and some tips on setting up a heatmap to visualize temperature across my home. Monitoring temperature can be crucial for comfort and energy efficiency, and visualizing it with a heatmap makes it much easier to spot trends or issues. Here’s how I approached it and some common pitfalls to watch out for.### Why a Heatmap?Heatmaps are a fantastic way to get a quick overview of temperature distribution in your home. They allow you to see patterns, such as cooler areas near windows or warmer spots near heating vents, at a glance. This can be especially useful for optimizing your HVAC system or identifying areas that might need insulation improvements.### Setting It UpI used Home Assistant for this project, leveraging the Picture Elements card to overlay temperature data on a floor plan image. Here’s a step-by-step breakdown:1. Gather Temperature Data: Ensure you have temperature sensors in each room. I used a mix of wall-mounted sensors and smart plugs with built-in sensors.2. Create a Floor Plan Image: I drew a basic floor plan using a simple graphic design tool. The image should be clear and include all rooms where sensors are placed.3. Configure Picture Elements Card: The Picture Elements card allows you to overlay images or elements on top of your floor plan. I used it to display the temperature in each room as a colored overlay.4. Color Coding: I set up conditional formatting to change the color based on temperature. Here’s a snippet of the code I used: yaml type: picture-elements elements: - type: image entity: sensor.living_room_temperature style: | left: 20% top: 30% width: 20% opacity: 80% filter: | {% set temp = states(‘sensor.living_room_temperature’) | float %} {% if temp <= 18 %} hue-rotate(240deg) # Cold (blue) {% elif temp <= 22 %} hue-rotate(120deg) # Mild (green) {% elif temp <= 25 %} hue-rotate(60deg) # Warm (yellow/orange) {% else %} hue-rotate(0deg) # Hot (red) {% endif %} image: /local/images/living_room.png 5. Testing and Adjustments: After setting it up, I tested it in different conditions to ensure the colors changed correctly. It took a few tweaks to get the positioning and opacity right so the overlays didn’t obscure the floor plan.### Common Issues and Solutions- Overlays Not Updating: Ensure your sensors are correctly configured and updating in real-time. Sometimes, a restart of the sensor integration or the Home Assistant instance can resolve this.- Color Not Changing: Double-check your conditional formatting logic. A small typo can prevent the colors from updating as expected.- Image Positioning: Use browser developer tools to inspect the elements and adjust the positioning until the overlays align perfectly with your floor plan.### Tips for Success- Use High-Quality Floor Plan: A clear, well-drawn floor plan makes the heatmap much more effective.- Regular Updates: Keep your sensors clean and in optimal positions to ensure accurate readings.- Customize to Your Needs: Adjust the temperature thresholds and colors to match your preferences and the layout of your home.I hope this guide helps you set up your own temperature heatmap! It’s been a fantastic addition to my home monitoring setup, and I love how it provides such a clear visual representation of temperature distribution. If anyone has questions or tips, feel free to share them below—I’d love to hear how others are tackling this!
