Hello Aqara Support,
I am experiencing an issue with my Aqara Climate Sensor W100 (model TH-S04D) when using it over Zigbee.
Device / setup
- Device: Aqara Climate Sensor W100
- Model: TH-S04D
- Connection: Zigbee via Zigbee2MQTT
- Zigbee2MQTT version: 2.14.1
- Device IEEE address: 0x54ef4410016c6eb9
- Firmware: 0.0.0_1641
- Firmware file version: 4137
- Firmware date code: 20260518
Issue
The W100 does not send any PMTSD commands when changing the thermostat setpoint through Home Assistant.
This also occurs when the W100 is not in thermostat mode: the expected PMTSD commands are not sent in that mode either.
When the W100 is put into thermostat mode and I attempt to change the setpoint through Home Assistant, the target temperature remains at 15°C and the W100 eventually displays E02. The PMTSD commands simply appear never to be sent
I also attempted a factory reset by pressing the reset button 10 times, but the normal 10× reset procedure did not work.
Because the normal factory reset did not work, I performed a protocol switch to force the device to reset.
Same E02 here (3× W100, fw 0.0.0_1641 / 20260518, Z2M 2.14.2, thermostat mode ON). Found a workaround that fixes it for me.
Cause: after you change the target on the W100, it sends a PMTSD frame and then waits for a reply (an Aqara hub normally answers). With Z2M + HA nothing is sent back if the value already matches, so after ~10 s the W100 shows E02. Sending the same setpoint back to the W100 clears it straight away.
Fix: an HA automation that echoes the value back ~2 s after each PMTSD:
alias: W100 ack (E02 fix)
mode: restart
triggers:
- trigger: state
entity_id: sensor.YOUR_W100_pmtsd_from_w100_data
not_to: [unavailable, unknown, ""]
actions:
- variables:
payload: >-
{% set s = trigger.to_state.state %}
{% set t = s | regex_findall('TW([0-9.]+)') %}
{% set p = s | regex_findall('PW([01])') %}
{% set d = {} %}
{% if t %}{% set d = dict(d, occupied_heating_setpoint=(t[0] | float)) %}{% endif %}
{% if p %}{% set d = dict(d, system_mode=('off' if p[0] == '1' else 'heat')) %}{% endif %}
{{ d | to_json }}
- condition: template
value_template: "{{ payload != '{}' }}"
- delay: 2
- action: mqtt.publish
data:
topic: zigbee2mqtt/YOUR W100 NAME/set
payload: "{{ payload }}"
Replace the sensor entity and Z2M friendly name. The write doesn’t make the W100 send a new PMTSD, so there’s no loop. No more E02 for me, and the target stays on screen.
Note: this only helps if your W100 does send PMTSD (you can see it in the PMTSD_from_W100_Data sensor). If yours sends nothing at all, the trigger never fires.
It would be nice if Z2M sent this reply automatically.
