W100 Wall Mount
Hallo, Are these Wall Mount available to buy individually? I bought some W 100, they weren’t there.
Hmm, these should be added to the packaging- I would complain at seller!
Alternative you maybe can 3D print one
Not the same but useful
https://makerworld.com/en/models/1418537-aqara-w100-wall-mount
I’d be interested to know that, too.
I only received a normal cover for one screw. However, when I press the buttons, the device always slips to the left or right. A cover with two screws would be better. Unfortunately, it looks like the 3D version is only for one screw too. I have no idea if that would really be better.
True, I’m sure someone already has designed one
There seem to be two models.
I apparently bought the one without the wall bracket.
And I have the two versions.
The one with the Wall Mount is much better. That’s why I want to retrofit it.
Didn’t knew about 2 versions! Good point now! So it’s no problem by the seller!
I don’t think that Aqara has a replacement part for it to buy as an extra
I would go for the stl. and print it
Yes, I’ve already looked, but none of them are good enough. Besides, I don’t have a 3D printer and I don’t have the space for one here.
