W200 pre prep due dilligence
In prep for the upcoming W200 thermostat (hopefully sooner rather than later) will the module (resistor pack?) I used to get a common wire for the eero thermostat work the same when the new W200 comes out? Would like to not have to get down inside the furnace again…
@YLMbN You seem to be experiencing an issue with whether the resistor pack module used for the eero thermostat’s common wire will work with the upcoming W200 thermostat. You can contact customer support for assistance.
I went ahead and ran new wiring that eliminates the need for the module so I will be ready for the W200.
@YLMbN That’s great to hear you’ve proactively prepared for the W200 by running new wiring—saves you the hassle of revisiting the furnace later! Thanks for sharing your experience; it might be helpful for other community members gearing up for the W200 too. Feel free to drop more updates once you get the thermostat set up—we’d love to hear how it goes
