W200 thermostat adaptive settings explained
@AqaraBot
Trying to determine actual behavior of the w200 thermostat set to Apple HomeKit control, with adaptive temperature engaged.
Normally, you set a thermostat to (for example) cool 70 degrees. Your system then maintains a 70 degree temp by activating cooling anytime the temperature rises above 70.
When you have it set to adaptive temperature with auto setting enabled - what does it do?
Let’s say it’s set to auto (for heat & cool) 66 degrees heat - 69 degrees cool. In general I guess it keeps the temp between 66-69.
So the temp falls below 66, the heat engages until… what? Until it heats to 66? Or 69? And if t he temp goes above 69 , it cools until….69? Or 66?
Seems highly inefficient though it claims to be high efficiency.
Also, if I tell Siri to change the temp to 70 degrees, it changes the heat & cool,set points accordingly but until when? Until Home, away or night is triggered?
@edjames Great questions about Adaptive Temperature behavior! Let me break this down based on how the W200 works with Apple HomeKit.
How Adaptive Temperature Operates
The Adaptive Temperature feature uses your iPhone’s location and activity states (Home, Away, Sleep, Vacation) to intelligently regulate climate control — not just simple setpoint tracking. It predicts when you’ll arrive home and pre-adjusts temperatures for comfort while saving energy when you’re gone.
Your Auto Mode Scenario (66° heat / 69° cool)
In standard thermostat logic (not specifically Adaptive Temperature), Auto mode creates a dead band between your heat and cool setpoints:
  • Temp drops below 66° → heat runs until it reaches 66° (not 69°), then stops
  • Temp rises above 69° → cooling runs until it reaches 69° (not 66°), then stops
The system maintains you between the two thresholds, not cycling to the opposite extreme. This prevents the inefficiency you’re worried about — it’s not heating to 69° or cooling to 66°.
The “Inefficiency” Perception
Adaptive Temperature actually improves efficiency by:
  • Pre-heating/cooling only when you’re actually returning
  • Using wider setbacks when Away or Asleep
  • Avoiding conditioning empty spaces
The “high efficiency” claim comes from occupancy-aware scheduling, not from the dead band mechanics themselves.
Siri Override Duration
When you tell Siri “70 degrees,” it typically applies as a temporary hold until the next scheduled activity state change (Home/Away/Sleep) or until you manually revert. This is standard HomeKit thermostat behavior — the override persists until the next schedule boundary or until Adaptive Temperature’s predictive logic takes over based on your movement patterns.
For precise hold duration control on the W200 itself, the Schedule Assistant lets you configure how long manual changes persist before schedules resume — default is typically 2 hours.
Worth Testing
Try checking your Home app history to see actual cycle behavior. If you’re seeing heat run past 66° toward 69°, that suggests either: (a) a larger hysteresis setting for equipment protection, or (b) the temperature compensation/calibration may need adjustment[“content_id:5”]. The W200 does support temperature compensation if sensor readings seem off.
Anyone else with the W200 noticed how aggressively it maintains the dead band in practice?
Welcome to the forum! I don’t use the W200, so I’ll leave the details to others, but you might get a quicker answer by adding which firmware version the thermostat is on and whether the behaviour is the same when you control it from Aqara Home instead of Apple Home.
You are correct
If you like the Temperature 72° 24/7/365 (or your perfect temperature) do not use the Adaptive Temperature option. Running the Air Conditioner in the Winter when it’s 10°F outside or running the Heater in the Summer when it’s 90°F outside is craZy.
I don’t care what Apple says.
I think its sensible practice to set the adaptive temperature limits sufficiently far apart that your HVAC system isnt activating cooling mode during heating season or activating heating mode during cooling season.
Based on this, I generally have my limits set to 68F and 78F since it is heating season here. Next spring I expect to adjust these for cooling season - maybe to 60F and 72F or something like that.
I have a 4 zone HVAC system with four Aqara W200s - one per zone.
I have some zones that use presence in the home to transition between several adaptive temperature ranges as follows:
68F to 78F whenever anyone is home
64F to 78F when no one is home
60F to 82F when no one has been home for 24 hours
I have other zones that use presence in the room to transition between several adaptive temperature ranges as follows:
68F to 78F whenever someone is in the room
64F to 78F when no one is in the room
I have been monitoring system behavior closely since I installed my Aqara W200s a few weeks ago. So far the system seems to be behaving reasonably well.
