Looking to see if or when Aqara W200 Thermostat will support Humidifier Control?
@davidbenson2 Great question! Based on the current reference info for the Aqara Thermostat Hub W200, humidifier control isn’t listed among its documented features or compatibility options. The W200 supports furnaces, ACs, heat pumps, boilers, PTACs, and fan coil units with up to 2-stage heating/cooling, plus auxiliary heating for heat pumps, but standalone humidifier terminals aren’t mentioned in the compatibility specs.
For timing on potential humidifier support, there’s no roadmap info available in the current materials. Since this would be a meaningful expansion of the W200’s capabilities, I’d recommend reaching out directly to get the latest word:
They’ll be able to confirm whether humidifier integration is on the radar or if there are workarounds using the existing terminal configurations. If you end up hearing back, feel free to share what you learn—always curious to see how folks are pushing these systems
Thanks have sent in the request.
Please update this post with their response. The compatibility checker states that when ‘HUM’ is selected the w200 may not be compatible.
This is the ONLY thing keeping me from upgrading as ecobee supports accessories like a whole-home humidifier.
Update from Tech support.
Regarding your question, the Aqara Thermostat Hub W200 does not support humidifier or dehumidifier control. The device does not have a U terminal (often labeled ACC+/ACC- on other brands), which is typically used for connecting humidifiers or dehumidifiers. If your existing system has a U terminal, we recommend insulating those wires with electrical tape and leaving them disconnected. The thermostat will still function properly for heating and cooling operations.
