W200 thermostat loosing synch with Apple Home
I have had some aqara devices move to a different room in AppleHome. They stay in the right room in the Aqara app. And, they look fine there. In both cases it has been a sensor (FP300 and contact sensor). Other sensors were fine. This has happened twice. Once when the internet went down for a few minutes. The other time was when I changed an Apple border router. The worst part of the problem was that I lost the automations associated with these sensors. What could cause this?
@dsmith_ds1954 Room “drift” in Apple Home (while everything still looks correct in Aqara Home) often points to the HomeKit side temporarily losing its normal link to the hub/border-router path—especially since you noticed it right after a brief internet outage and after swapping an Apple border router.
A key thing to check is whether your Aqara hub/camera and your Apple Home Hub (Apple TV/HomePod) are consistently staying on the same LAN. HomeKit responsiveness and state sync rely on both being on the same local network; if that relationship changes (router swap, network segmentation, different SSID/VLAN, etc.), you can see odd Home behaviors like “No Response” or inconsistent metadata syncing【This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.】. Original post link: https://attachment.freshdesk.com/inline/attachment?token=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpZCI6NDgzNzk2NTMyMTcsImRvbWFpbiI6ImFxYXJhaGVscC5mcmVzaGRlc2suY29tIiwiYWNjb3VudF9pZCI6MTE1MTM5Nn0.qhdxLnYzIwbE6ds5bU1Nhb2-ZWx-2pG2U2xbxpe7HF8)
If it keeps happening, the usual “clean-up” step on the HomeKit side is to remove the affected accessory from Apple Home and add it back by scanning the HomeKit code again (this can reset HomeKit’s cached info for the accessory)【This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.】. Original post link: Aqara知识库)
If you want, share what your Apple Home Hub is (Apple TV vs HomePod), whether you run multiple SSIDs/VLANs, and whether the Aqara hub is on 2.4 GHz while your Home Hub is wired/5 GHz—those details can help narrow down why the LAN relationship changes after network events.
I had this issues when I first added my device. When I restarted my router and hub, I stop having the disconnection
I see the same thing with my FP300s but usually only after the M3 hub they are connected through rebinds to the matter server. Everything all good in Aqara home app, but I see the devices in HA have rebound (either duplicated entity id’s but with _1 after the entity name). The new entities are live and old entities are unavailable which breaks automations to your point.
Do you have your devices going into Home Assistant or just using AppleHome? HA has a great service called Watchman which I have running on a schedule to check for unavailable entities and scripts with entity id errors.
I had tried rebooting the aqara hub/w200 and the head apple border router earlier at the same time. After I submitted this post, I started having issues with my thread network going down and coming back slowly. I was also getting 502 errors on the Aqara side. I eventually determined that the thread network going down was that I had my iPhone setup for what I will call a Dynamic MAC address (it is also called something else commonly as well. It is designed to keep your data more secure from hacking on a public network. I changed it and thread became reliable and fast again. I determined that the 502 errors were an error on the Aqara server side. This fixed itself after about a day. I also found out that if I had an M3 Hub, it will make my dependence on Aqara servers much less. So, I guess, I will be spending more money before too long.
I am stilll having a problem with Apple not recording logs related to the adaptive temperature feature. It did for about a day or two when I first setup the w200. But it quit for some reason. When I removed the w200 from apple home and reconnected it through matter, I hoped it would fix this, but it didn’t. But it. didn’t help that issue. The door lock logs are working fine. Supposedly this problem is a matter issue of not moving that data through the network back to apple home. Any ideas?
Thanks for all help.
@dsmith_ds1954 You did a lot of solid detective work here—especially isolating the Thread instability to the iPhone’s “Dynamic/Private Wi‑Fi Address” behavior. That kind of LAN identity churn can absolutely make Thread/Matter ecosystems feel flaky.
On the remaining bit (Apple Home not recording adaptive temperature logs): I don’t see anything in the current Aqara reference notes that specifically covers Apple Home’s logging pipeline for W200/adaptive temp, so I can’t give you a guaranteed fix without guessing.
What is worth trying from the known-good side:
  • Re-check / re-enter W200 wiring settings in Aqara Home (because rewiring clears previous settings, and if you’re using Matter it also clears ecosystem settings):
    Aqara Home app → Accessories → Thermostat Hub W200 → … → Device Settings → Wiring
If the wiring/working mode inside Aqara changes (even subtly), Apple Home’s exposed characteristics/events can change too—so confirming this is one of the few “official” levers we have documented for W200.
If that doesn’t change Apple’s logging behavior, I’d treat it as an Apple Home/Matter telemetry/logging issue that needs deeper troubleshooting (Home Hub model, iOS/homeOS versions, Matter fabric health, etc.). The fastest path is to get it in front of support with your setup details and a short timeline of when logs stopped.
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket. Sorry for the inconvenience.
If you share what your Apple Home Hub is (Apple TV 4K gen/Thread vs HomePod mini vs HomePod 2), and whether W200 is added via Matter over Thread or Matter over Wi‑Fi, folks here can compare notes on whether Apple Home is expected to log that specific adaptive-temperature data today.
