W200 Unable to Join Existing G410 Thread Network
Hello, when attempting to add a W200 thermostat to the existing thread network created by a Google TV Streamer, and which a G410 has already joined, an error message pops up stating that the device must be connected to the same network, despite that being the case.
The W200 and all devices are on the same network.
Before this as well, The G410 and W200 were on their own Thread networks but neither could join the other due to the same error as above. I tried factory resetting the W200 but that seems to have exacerbated the issue.
Now, the W200 is unable to join any Thread network after being reset. Screenshots show the UI/UX when attempting to select a Thread network for the W200. My mobile device is also on the same network. Any ideas?
Hi, two things i would check in this case , 1) the phone that you use for paring is on 2.4GHz (not 5GHZ) wifi band , 2) IPV6 enabled on your router.
