W200 Virtual Soft Sensor from Matter
I managed to get soft sensors set up and it’s been really great! Having control to publish values, switch, or average whichever I want has been something neither Nest nor any other thermostat could do.
But I do have to publish the same value twice and average them. Did I overlook any tricks to using a single matter temperature sensor directly?
Oh, and is there any point in sending custom humidity measurements? I’m not sure if the W200 uses that for anything with soft sensors.
Could you give a few more specifics on the publishing twice and averaging?
If you care to control W200 thermostat based on humidity level or setpoint you can.
