Hi, I have recently set up a heating system with 7 rooms, each containing a W600 Thermostat. I have a T2 relay with output 1 connected to my boiler, and if any of the rooms call for heat, the relay switches on. This works fine.
I have further set up a ‘Boiler Off’ automation where the trigger is when any of the 7 thermostats reach or are above their set temperature. This is then checked against the AND statement to see if all of the other 6 thermostats are also above their set temperatures, and if so, the T2 relay (Boiler) is turned off.
Again this works fine.
I have the system linked to Apple Home which is my main interface for controlling my smart home. I am finding that family members are accidentally pressing the tile in Apple Home and turning off the thermostat. As such, the conditions within my automations are never met and the boiler stays on unnecessarily.
I would like to create an automation where the ‘AND’ statement is able to understand whether a W600 is either above its set temperature or is turned off. Ideally something like this:
WHEN: Any thermostat temperature or mode changes.
AND:
Thermostat 1 is Off OR Current Temp is greater than Target Temp
Thermostat 2 is Off OR Current Temp is greater than Target Temp
Thermostat 3 is Off OR Current Temp is greater than Target Temp
THEN: Set Dual Relay T2 — Output Off.
I can’t find a way of writing this in the Aqara app. I believe if I write individual automations, I will need 128 of them to cover all 7 instances.
Any help or guidance would be appreciated. Thanks
@davidcwillmott Hello! Thanks for sharing your detailed heating setup. It’s impressive how you’ve integrated the W600 thermostats with the T2 relay for boiler control, especially with the Apple Home integration. I understand the frustration when accidental taps in Apple Home disrupt your carefully crafted logic, leaving the boiler running unnecessarily.
Regarding your request to create an automation where the condition is “Thermostat is Off OR Temperature is above set point,” I’ve checked the available automation conditions for the Aqara Thermostat W600 and the Aqara Dual Relay Module T2.
Currently, the Aqara Home App’s automation engine for thermostats typically supports conditions like “Temperature is above/below the set temperature” or “Turn on/Turn off.” However, it does not currently support complex logical operators like “OR” within a single IF condition block for multiple devices, nor does it natively support combining a “Device State (On/Off)” with a “Temperature Threshold” in a single OR clause for the W600 in the way you described. The app generally requires you to select one specific trigger type per condition line.
Since the native app interface doesn’t seem to support this specific “OR” logic combination for your 7 thermostats directly, and creating individual automations for every combination would indeed be cumbersome, this falls under a feature limitation or a complex scenario that requires specific configuration support.
You seem to be experiencing an issue with configuring complex logical conditions (OR logic combining device state and temperature) in the Aqara Home App for your W600 and T2 setup. You can contact customer support for assistance.
This will be more efficient. If you do not have an Aqara Home account, “Please
click here” to create a ticket.
If you have Home Assistant, this is much easier to do there than in the Aqara app. One template can check whether any room that is switched on is below its target, and drive the T2 relay from that. A thermostat someone has tapped off then drops out of the check instead of blocking it. I’m planning the same any-room-calls-for-heat logic in HA for my own Aqara valves, because the app can’t do this kind of OR condition.
