W600 temparture problems
I am experiencing persistent temperature measurement issues with three Aqara Radiator Thermostat W600 devices and would appreciate a technical investigation and a concrete solution.
My setup
  • eight Aqara Radiator Thermostat W600 devices.
  • All devices are connected directly to a Homey Pro 2026 via Matter over Thread.
  • Firmware version: 1.0.1.1 on the devices.
Problems observed
  1. All three thermostats report a temperature approximately 4.5°C lower than the actual room temperature.
  2. The temperature difference is not constant. It changes over time, making a fixed temperature offset or calibration unsuitable as a permanent solution.
  3. The temperature displayed on the thermostat itself can remain unchanged for a prolonged period, even when the actual room temperature changes noticeably.
  4. Homey receives the same temperature value that is displayed on the thermostat. This suggests that the discrepancy is already present at the device level, rather than being caused by Homey displaying a different value.
  5. I have tested temperature compensation in Homey. It changes the reported value, but it does not solve the changing temperature discrepancy.
Since all eight devices exhibit similar behaviour, I suspect a possible firmware issue or a problem with the temperature measurement and update mechanism.
Could you please clarify the following?
  1. Is this a known issue with the W600 running Matter over Thread firmware 1.0.1.1?
  2. How frequently should the W600 measure and update its actual room temperature, both on its display and via Matter?
  3. Is there a newer official firmware version that addresses inaccurate or delayed temperature measurements?
  4. Can the internal temperature sensor be calibrated directly on the device, or is calibration only available through the Aqara app?
  5. Is there a recommended troubleshooting procedure for this specific issue that does not require switching from Matter/Thread to Zigbee?
  6. If this is a known hardware or firmware defect, what corrective action do you recommend?
I would appreciate a specific technical response rather than general advice to adjust the temperature offset, as the deviation varies over time and cannot be corrected reliably with a fixed value.
Peter
In the meantime, I have done the following:
  • Installed the Zigbee firmware on the Aqara W600 using the official Aqara app. I then removed the device pairing.
  • Downloaded the Aqara Community App.
  • Selected the correct radiator thermostat through the “Add Device” function in the Aqara Community App.
The connection was established, and the temperature control started working. However, the temperature deviation remained. I then corrected the temperature to the actual room temperature under the advanced settings. Even then, the temperature control continued to work properly.
It is frankly unacceptable that this does not work via Matter and the official Aqara Homey app. Fortunately, it is now working using this alternative method.
