Hi!
One of my friends are building a new home. The heating will be made with a gas boiler system with central heating valve in floor heating system. Can he use the W600 thermostat heads on the central valve system + each room has one temperature sensor? The temperature measuring will be fine?
Hello, one W600 thermostat (central valve) and a group of W100 temperature sensors (several pieces) will not be able to evenly control the temperature in different rooms.
The central valves are separated by rooms, one valve for one room. So there could more W600 one for each room.
Aqara TVR W600 is a proportional regulator with PID feedback, designed to work on a radiator. It will not work for your problem.
You can use TVR E1 for this. This thermostat
works on the On/Off principle. If you use a remote thermometer W100, it will be fine. The disadvantage of E1 is that the batteries will soon “burn out”.
Yes that should be able to work depending if the W600 heads is compatible with the valve setup. It is a good idea to have one T.S per room and if isn’t in the correct place that should control room temp.
Hello, unfortunately, in PID, the controller additionally measures the temperature around itself, which will lead to poor control performance (the W600 will be placed in a separate niche where the valve block for floor regulation is located). This is how I imagine the scheme of water underfloor heating.
