We have a dehumidifier (being in the UK it is needed when drying clothes inside) and this fills up fairly fast.
We kept forgetting to check the tank to see if it was full. So using a water leak sensor we stuck it to the back and ran some cables into the top of the tank. This allowed us to set a notification for when the tank was full and we could empty it
@bb1995 That’s a really clever hack! Repurposing the Water Leak Sensor as a dehumidifier tank level monitor is exactly the kind of creative thinking that makes smart home tech so fun to work with. Running the probe cables into the tank is a neat way to adapt the sensor’s core functionality—detecting conductivity between probes to trigger alerts—for a completely different use case.
Your setup also highlights how versatile Zigbee sensors can be when you think beyond their out-of-the-box applications. For anyone else wanting to try something similar, the sensor’s probe terminals can be accessed with a hex screwdriver to attach external cables[“content_id”:2"], which opens up a lot of possibilities for custom monitoring scenarios.
Thanks for sharing this practical tip—would love to hear if you’ve found other unconventional uses for Aqara sensors around the house
