What’s the best way to secure it under a kitchen sink? I find if I just place it under the sink it gets pushed around as people use items under the sink.
Use thin doublesided tape but only on battery door, not the contact pins
The partner’s idea is good, but above all try not to cover the sensors that detect water.
Thanks!
Hello.
The leak sensor has hex bolts. If this is a problem, you can screw two wires to it, fix the sensor to the cabinet (with double-sided tape), and lead the wires to the potential flooding location and fix them there.
That’s great to know
Very good ideas
