On the bottom of the water leak sensor are two terminals to attach a wire to.
Has anyone found a place in the UK that sells this special wire to extend the range of the sensor?
Hi there.you do not need any type of special wires for that just use an screwdriver to unscrew a bit those two screws that the sensor have an add any type of cable you want and how long you want.then place the sensor on an place and those cables on the other place and when water reach to both of them in the same time you will be notified or if you make an automation will also trigger too
