Water Softener automation?
Hey all, just wondering if anyone’s tried using a water leak sensor for a water softener? I always struggle to setup a reminder for when my salt levels are too low for my water softener and I had bought a “Salt Sentry” a while ago but couldn’t get it setup reliably. I had the insipiration to just toss in an Aqara Water leak sensor into the water softener and setup an automation that when it detect water when my salt levels get too low, it would fire me a notification. Unfortunately, when the sensor touched the water it didn’t trigger an alert.
Has anyone else tried something like this? Is there maybe an issue with the salt content in the water that prevents the sensor from triggering?
Any thoughts appreciated!
@davetsang Using an Aqara Water Leak Sensor for monitoring water softener salt levels is an innovative idea! The Aqara Water Leak Sensor operates by detecting the electrical conductivity of water - when the sensor’s probes contact water, a current loop is formed, triggering an alert. However, the presence of a high salt concentration in the water might affect the sensor’s ability to detect this conductivity effectively.
Here are a few things you might consider:
  1. Sensor Sensitivity: The sensor is designed for detecting water leaks or flooding situations. It might not be calibrated for the specific conductivity levels present in a water softener.
  2. Placement and Contact: Ensure that the probes of the sensor are in direct contact with the water. Sometimes, placement can affect detection.
  3. Signal Interference: The sensor should ideally be placed on a non-metallic surface to avoid interference.
  4. Alternative Methods: If conductivity is the issue due to salt, you might want to explore other sensor types specifically designed for salinity or salt level detection.
While this setup might face some challenges, it’s a creative approach! I encourage you to experiment with placement or consider additional sensors that might be more suited for salinity detection. If anyone else in the community has faced similar challenges or has solutions, your input would be greatly appreciated!
@davetsang Hey there! It’s a clever idea to repurpose the water leak sensor for monitoring salt levels—kudos for thinking outside the box. Let’s break down what might be happening here.
Aqara water leak sensors work by detecting the electrical conductivity of water: when two probes come into contact with water, a current loop forms, triggering the sensor to report a leak . If your sensor isn’t triggering when it touches the water in the softener, it’s possible that the water’s conductivity is too low. Salt (sodium chloride) increases water’s conductivity, so if the salt level is very low, the water might not conduct electricity well enough to activate the sensor. That could explain why it’s not triggering as expected.
Has anyone else in the community tried a similar setup? Your experience could help shed light on workarounds or adjustments—feel free to share!
Hope this helps spark some ideas, and thanks for sharing your project with us!
@davetsang Hey there! It’s great to see you getting creative with your Aqara Water Leak Sensor—love the problem-solving mindset. Let’s break this down based on how the sensor works.
The Aqara Water Leak Sensor uses the electrical conductivity of water to detect leaks: when its two probes contact water, a current loop forms, triggering the alert . If your sensor isn’t triggering when in the water softener, the salt content could be a factor. Water with lower salt levels might have reduced conductivity, which might not activate the sensor’s probes as intended. Since the sensor is designed for leak detection (not specifically salt level monitoring), this use case is a bit outside its standard function, which could explain the inconsistency.
Have others in the community tried this? It’d be awesome to hear if anyone has tips or workarounds. If you experiment further, feel free to share your findings—we’re all here to learn!
Hope this helps, and keep the smart home hacks coming!
@davetsang Hey there! It’s great to see you getting creative with your Aqara Water Leak Sensor—repurposing it for salt level monitoring is a clever idea. Let’s break down what might be happening here.
First, Aqara Water Leak Sensors work by detecting the electrical conductivity of water: when two probes come into contact with water, a current loop forms, and the sensor sends an alert . If your sensor isn’t triggering, it could be related to the conductivity of the water in your softener. Saltwater typically has higher conductivity than pure water, but if the salt level is very low, the water might have lower conductivity—possibly too low for the sensor to detect. That said, the reference info doesn’t specifically address salt content, so this is a potential angle to explore.
Have you tried testing the sensor with regular tap water to confirm it works? That could help rule out a sensor issue. Also, maybe adjusting the probe placement (ensuring they’re fully submerged when salt is low) might make a difference.
Has anyone else in the community tried this? Your experience could spark a great discussion—feel free to share updates if you tinker with it more!
Thanks for sharing your project—innovative uses like this are what make the community awesome. :blush:
Note: The above is based on available reference information. For further clarification, you can also reach out to Aqara Customer Service through the app if needed.
