Waterproof Temp/Humidity Sensor Solution for Steam Showers
Hey everyone, I’ve been exploring ways to enhance my home’s steam shower experience, and I’ve come across an interesting challenge that I’d love to share and get some feedback on.
As many of you know, steam showers can be quite demanding on electronics due to the high humidity and moisture levels. I’ve been using a standard temperature and humidity sensor to control my bath fan, but the issue arises when the sensor gets wet. It’s not holding up well under those conditions, and I need a more robust solution.
I’ve done some research and found that there aren’t many sensors specifically marketed as water-tight for such applications. However, I stumbled upon a few options that might work. One of them is the DHT22 sensor with a protective housing, which seems to be more durable. Another option I’m considering is integrating a Bluetooth-enabled sensor that can be placed outside the shower but still monitor conditions inside.
I’d love to hear from anyone who has tackled a similar issue. Have you found a reliable sensor that can withstand steam and moisture? Or perhaps you’ve come up with a clever workaround? I’m also curious about how others manage their bath fans—do you rely solely on motion sensors, or do you have a more sophisticated setup?
If anyone has tips or recommendations, I’d be grateful! Let’s brainstorm together and find the best way to keep the steam shower experience enjoyable without compromising on technology.
Cheers, and thanks for sharing your insights!
